Ricoh Pro C550ex Questions
  • Tim C
    • 167
    Hi all, Just wondering about a Ricoh Pro C550ex. I am considering buying one of these Machines.
    Is it a good machine to work with for heavy use? it presently has a Toner cartridge issue with the Magenta not being recognized.
    I haven't decided weather I should get involved with this machine or not, It only has 140k total prints and a fiery unit.
    Thanks for any and all input
  • copier tech
    • 8190
    Re: Ricoh Pro C550ex Questions
    Bit dated now, id go for a low millage Pro C5110S.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Agree with copier tech
      Old model and was not a very good one at that also 140k seems very very milage for one of these age of machine
      Regards Mark
      • skinnyb
        • Jul 2008
        • 291
        Agreed, very old machine. And even when they were brand new they were toner belching Beast. Not my favorite model by far.
        Sent from my LM-V405 using Tapatalk
          • 37556
          With a machine that old I would be more concerned with the potential for mechanical failure like broken gears in the fusing unit. If you buy one you may want to have a spare fusing unit on hand because parts can take time to get.
          Toner belching can be handled but will be expensive to do. Machine will need a full PM. That means all spewed toner cleaned, applying a laundry list of service bulletins issued to correct CQ problems and toner dropping and then making changes in SP settings to slightly reduce the toner concentration in all the development units so that less toner is applied to the drums and very slightly increasing transfer currents so that more of the toner on the drum is ends up on the paper instead of the waste toner.
          They are a very maintenance hungry machine but make beautiful copies as long as you are ready to spend the time and money to maintain them.
