MPC3504
  • Elmo
    • Feb 2010
    • 541
    MPC3504
    Hi All
    Got an MPC3504 in a batch of machines
    All powers up ok but when i go to utilities login as Admin
    then try to select any of the options this screen pops up (does the same with the finisher attatched)
    i have updated latest firmware package, tested a screen from another machine and
    have reset the screen to factory default
    been working on other brands for a few years so if its a know fault forgive my lack of knowledge
    it looks like a firmware /software issue not sure any ideas
    I Used To Live To Fix Things Now i Fix Things To Live
  • 8T2
    • Aug 2015
    • 257
    Re: MPC3504
    Haven't had a recent machine do this but the last one (MPC2800 or something) that did something similar had the wrong panel fitted
    Sent from my WAS-LX1 using Tapatalk
      • 37535
      Re: MPC3504
      Looks like you may have a faulty cover switch. The partial image at the bottom left of the screen appears to be part of the duplex paper path.
      • Elmo
        • Feb 2010
        • 541
        Re: MPC3504
        i will check out the door switches
        was wondering why it was such a scrambled image
        • Jethro
          • 4
          Re: MPC3504
          I'd print the diagnostic page (SP 5-990-005) and verify the individual firmware modules are all correct, as listed in the current Firmware History PDF.
          I'd specifically be checking the animation, LCDC, and/or OpPanel firmware module. (I don't have a MP Cxx04 series machine handy so I'm not sure of the exact module names on that one.)
          • Elmo
            • Feb 2010
            • 541
            Re: MPC3504
            i downloaded and used the latest package from Ricoh
              • 37535
              Re: MPC3504
              Package only updates modules that are not current. It does not replace corrupt modules because it is not able to detect them. You have to use individual modules.
              • Elmo
                • Feb 2010
                • 541
                Re: MPC3504
                You learn something new every visit
                Thanks will try all the individual modules
                • Jethro
                  • 4
                  Re: MPC3504
                  Additionally, on some models - not sure if it applies to MPCxx04 series - the package will install OpPanel firmware that is for the Taiwan region instead of for NA. I've not actually seen it pose a problem, but if that's the case here I'd certainly update that module as well.
                  • Elmo
                    • Feb 2010
                    • 541
                    Re: MPC3504
                    update all modules individually still no difference
                    Got out a bigger hammer lol
                    Checked door switches turned out to be faulty cassette pedestal
                    still had issue with incorrect info on screen
                    so swapped screen from a working machine and now all ok
                    just need to sort out the 3 faulty screens i have
                    any 1 help with advise on updating screen firmware via the card port on the screen
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      Re: MPC3504
                      Drop the firmware zip on an SD card, stick it in the side of the panel, boot into recovery mode (hold EX1 and EX3 on power up, switch to EX1 and EX2 when the display shows the first image), select update from SD card.
                      Hit it.
                      • FrohnB
                        • Jul 2017
                        • 1919
                        Omertà
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          Re: MPC3504
                          Hi All
                          [ATTACH=CONFIG]47628[/ATTACH]
                          Looks like wrong screen fitted to me also is a ex version make sure you download correct firmware download package install. In machine sd card slot it will also up date screen firmware the same time
                          Regards Mark
                          • Jethro
                            • 4
                            Re: MPC3504
                            Once you've downloaded the SOP OS firmware, and unzipped it, there's a readme file that describes the process pretty well.
                            For the 3(!) "faulty" screens - I've never had to do it but some have mentioned clearing the cache on the Android device. Once you boot into Recovery Mode (like when updating the OS firmware) there's an option to clear the cache in there.
                            Like I said, I've never had to do it but have seen others mention having success with some issues.
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              Re: MPC3504
                              Hope this helps
                              Regards Mark
