Toner Dusting on LSU slit glass
  • technic83
    • Aug 2019
    • 10
    Hello,
    I have a C651ex, i have a reoccurring problem with toner dusting up onto the slit glass for the LSU.
    It stared with one machine and replaced the filters and seals for the top of the dev and toner entrance. I even swapped the PCDU with another machine and the problem followed the PCDU. So next I replaced the PCDU. Couple of days later I'm down here again cleaning the slit glass from dusting.
    Is there a setting or a page in the SM or a mode I can change to help stop it?
    If you can just point me in a direction to look at
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Toner Dusting on LSU slit glass
    Originally posted by technic83
    Hello,
    The problem is you not setting up not good to swap from other machine replace developer and setup correctly also make sure the filters are clean or new
    Regards Mark
      • 37396
      The procedures in the attached may help. The first 10 pages apply only to lower speed machines. You need to start on page 11. Service Program (SP) Settings.pdf
