aficio cl 7000
  • DINGO
    • 661
    aficio cl 7000
    hy
    anybody nows if the copier/print ricoh aficio cl 7000 have any sensor that read the toner density whewn do a calibration adjust , that must be clean??
    thanks.
  • K.I.S.S.
    Staying Humble
    • 8
    The I.D. sensors are responsible for this function and need to be kept clean.
    Because the sensor patches are read off of the transfer belt...the belt must also be in good condition for calibration to complete successfully.
    New to board...hello KK
    sigpic"Someday, I'm going to make a big invention." ~ Chester Carlson ~
    • KopyKat
      Nurse Ratched of Repair
      • Nov 2008
      • 365
      Yeah what he said.
      Hi KISS. Welcome now just stay out of trouble.
      sigpic
      Relax! This firmware injection won't hurt...but it will take 45 minutes.
      • K.I.S.S.
        Staying Humble
        • 8
        Originally posted by KopyKat
        Yeah what he said.
        Me? Trouble?...Never
        • E Winter
          let me guess - you guys know each other^^
          Well afaik the toner density is readed by the td sensors. The ID sensors are mainly used for the color registration. Like already said these ID sensors and the condition of the transfer belt must be clean AND the image densitsy must not bee too light to ensure a proper, automatic calibration.
          • KopyKat
            • Nov 2008
            • 365
            Well I think I so. I believe ran into KISS at a highway rest stop once or twice.
            sigpic
            • techspec
              • Dec 2008
              • 128
              The silver rollers also on the transfer belt assy need to be kept clean, if these are dirty or scummed up they can give poor readings to the id sensors. So best cleaning these when replacing transfer belt.
              All TD sensors are located in the dev units, if they fail during process control you will be faced with SC370-SC373.
              • DINGO
                • 661
                • K.I.S.S.
                  Staying Humble
                  • 8
                  There are three I.D. sensors, all on one assembly.
                  It is located between the black PCU & the fuser.
                  • KopyKat
                    • Nov 2008
                    • 365
                    The ID sensor unit is at the upper left edge of the transfer unit. If you pull out the transfer unit you can see the unit. Removing it to clean well is very easy. see attached #15
                    sigpic
                    • KopyKat
                      • Nov 2008
                      • 365
                      KISS...you beat me to it...BUT I have pictures!
                      sigpic
                      • DINGO
                        • 661
                        re
                        • K.I.S.S.
                          Staying Humble
                          • 8
                          DINGO,
                          Your English is much better than my Portuguese!
                          • DINGO
                            • 661
                            • nilsonmorales
                              hola
                              hi dear tech kopykat can you sand me manual of this aficio cl7000 please. in mail ..copymanuals2@gmail.com
