I have a Crazy AF-1515MF
  • RebelPhoenix
    • Oct 2008
    • 138
    Hello Dear,
    I have a crazy ricoh af-1515mf.
    I turn on the machine and gw controller after is run, it's ok.
    a few seconds after Fax options button is red light. I click this button and show the this screen. " Func. Problems Data will be initialized. " and show a button on screen "OK" I click the ok button. After machines turn off the fax options I click the fax button but machines beep beep a few seconds after a message show on screen. " Problem: Adress book data. All data has ben deleted."
    C-107-C- 2. Fax SP. - Ram. Erase all files- Execute
    After I turn off machine after turn on machine and problem is not found. After I turn off the machine a night. I turn on the machine next day. Problem is show.
    I suspect or thinking maybe battery is end on mbu. or battery is not charge.
    I'm waiting your reply.
    Best regards
  • KopyKat
    Nurse Ratched of Repair
    • Nov 2008
    • 365
    Most likely either the battery on the fax option is dead or the jumper on the board to turn the battery on is not in the right position. The jumper must be shorted (jumper set to connect both pins).
    sigpic
    Relax! This firmware injection won't hurt...but it will take 45 minutes.
    • K.I.S.S.
      Staying Humble
      • 8
      +1.
      sigpic"Someday, I'm going to make a big invention." ~ Chester Carlson ~
      • RebelPhoenix
        • Oct 2008
        • 138
        Thank you so much for your reply kopykat.
        So this jumper isn't attached on FCU. (jumper set to connect both pins). it is short.
        • E Winter
          Originally posted by K.I.S.S.
          +1.
          +2
          ...and sometimes the MBU itself isn't connected properly on the fax board.
          • pro.b.unal
            • Dec 2008
            • 42
            Originally posted by Jan Sommer
            +2
            hi friend
            check te MBU- fax board connector and jumper sw on position.
            Adress book message= enter the Copy Sp mode 5846-50 UCS settings Adress book All İnt. execute
            Enter the Fax sp= 2103-1 (Com. sw) enter the TURKEY code 20 setting
            1104-01 Bit sw = 0000 0000 setting ECM mode OFF position
            • RebelPhoenix
              • Oct 2008
              • 138
              Try
              Hi dear pro.b.unal,
              Firstly thank for your answer,
              I try this settings after I gvie the information for this problem.
              Best regards
              Originally posted by pro.b.unal
              hi friend
              • RebelPhoenix
                • Oct 2008
                • 138
                I perform this setting now machine is turn off. I'm wait one or two day. After turn on the machine and I observation the machine after I write good news on this topic.
                Best regards
                So Thank you for your reply.
                • iMind
                  Vacuum Cleaning Expert
                  • Mar 2008
                  • 1116
                  "1104-01 Bit sw = 0000 0000 setting ECM mode OFF position"
                  hehehe, turning OF EMC= Error Correction
                  even if you recieve a half page fax it will be considered as a full recieved fax, TX will recieve OK after sending.
                  Well you never know how things work in Turkey, maybe you call RX and ask if he recieve a full paged fax, LOL...
