Hello Dear,
I have a crazy ricoh af-1515mf.
I turn on the machine and gw controller after is run, it's ok.
a few seconds after Fax options button is red light. I click this button and show the this screen. " Func. Problems Data will be initialized. " and show a button on screen "OK" I click the ok button. After machines turn off the fax options I click the fax button but machines beep beep a few seconds after a message show on screen. " Problem: Adress book data. All data has ben deleted."
C-107-C- 2. Fax SP. - Ram. Erase all files- Execute
After I turn off machine after turn on machine and problem is not found. After I turn off the machine a night. I turn on the machine next day. Problem is show.
I suspect or thinking maybe battery is end on mbu. or battery is not charge.
I'm waiting your reply.
Best regards
Best regards
