SC995-01
  • malatsi.koko@moreyitechno
    • 4
    SC995-01
    Hi,
    I have replaced the controller board on Ricoh MP 3054 now i am experiencing the above error (SC995-01) serial number mismatch.
    What else can I do to fix this.
    When I put the new NVram it does not allow me to go into service mode and freezes instead and get SC819-00 error
    Please advise
  • 8T2
    • Aug 2015
    • 257
    Re: SC995-01
    Haven't had to do this on a 54 yet fortunately, have you tried disconnecting, LAN cable, fax unit and HDD and starting up with a door open? If you're lucky it will start up so you can get into service mode.
    What happens if you start it up with the original NV RAM (if it's available that is)?
    Sent from my WAS-LX1 using Tapatalk
    • TonerMunkeh
      Professional Moron
      • 3865
      Re: SC995-01
      Was it a new controller? If not, the serial number from the old machine will be in there. Go to 5811 in factory SP and input the correct serial number.
      Hit it.
        • 4
        Re: SC995-01
        Its a used controller
        Thanks for your contribution
          • 4
          Re: SC995-01
          It is a used controller which was working sine on another machine, when I use the same NVram it gives me sc995-01 error.
          Tried to replace the brand new NVram and it I get SC819-00 that when it freezes and not letting me into the service mode
            • 4
            Re: SC995-01
            Haven't had to do this on a 54 yet fortunately, have you tried disconnecting, LAN cable, fax unit and HDD and starting up with a door open? If you're lucky it will start up so you can get into service mode.<br>
            <br>
            What happens if you start it up with the original NV RAM (if it's available that is)?<br>
            <br>
            <br>
            <br><br>It is a used controller which was working sine on another machine, when I use&nbsp; the same NVram it gives me sc995-01 error.<br>Tried to replace the brand new NVram and it I get SC819-00 that when it freezes and not letting me into the service mode
            It is a used controller which was working fine in another machine.
            With the NVram which was already in the controller, it gives me 995-01 (serial number mismatch)
            A brand new NVram i get SC819-00 and does not take me into setup mode, freezes instead
            • Gift
              • Mar 2011
              • 2459
              Re: SC995-01
              Try the used nv ram again - I think in factory sp there's something like "serial number input". You must compare three serial numbers - they have to be all the same. I guess there's some sort of mismatch.
                • 37628
                Re: SC995-01
                Originally posted by malatsi.koko@moreyitechno
                Hi,
                Please advise
                Was there a reason for replacing the controller? Did you follow the procedures in the service manual exactly, including discharging any residual on the donor machine before removing the controller from it? If you did not you might now have 2 controller boards that are toast.
                • copier tech
                  • 8222
                  Re: SC995-01
                  As slim said, start again & follow the correct procedure.
                  When you fit the original board back with its original NVRam what error do you get? (if any)
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Re: SC995-01
                    +1 on slimslob & copier tech just follow manual it tells you where you went wrong
                    Regards Mark
                    • slot
                      • Jul 2008
                      • 341
                      Re: SC995-01
                      Enter the machine serial number using SP5-811,you will need to enter SP via special mode and use the original nvram
