Ricoh MP 6500 ScanRouter
  • thurmmy
    • Aug 2016
    • 102
    My customer's IT is trying to disable scans to the ScanRouter. He has configured the scan to folder and disabled the ScanRouter but the copier is not recognizing that the ScanRouter has been disabled and continues to point to that server. Any ideas on how he can force it to use the local configuration? My understanding is that the servers that are currently using the ScanRouter are being retied soon and they are wanting to get the scans to the new server.
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh MP 6500 ScanRouter
    Can't they just uninstall the program? Ancient technology.
    NEVER ASSUME ANYTHING
      • 37490
      "Delivery Option" needs to be turned 'OFF' in user tools.
      Also check SP 5845-005 Capture Server IP Address. It will contain the IP address that was set when ScanRouter was installed.
      • thurmmy
        • Aug 2016
        • 102
        Thanks and I will check on these.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Correct!!
          I walked down that road many times, where ScanRouter had been removed.
          • sandmanmac
            • 3981
            I 3rd that emotion!
            That 'delivery option' is under file transfer I believe.
            I can't believe this old, dead and buried, long forgotten (and not missed), software has yet again so rudely re-emerged right before the New year!
              • 37490
              Originally posted by KenB
              Here's a little nugget you prolly won't find anywhere else...
              If you run an SMC report, there is an entry for "Use Cherry Server", which is either on on off. (I don't remember the number, sorry.)
              "Cherry Server" was ScanRouter Pro, which was different from Lite.
              Different yes, but still required 'Delivery Option' to be ON in order to work.
