Mac scan to ricoh MP 5004 or MP4054
  • aviso66
    • Dec 2012
    • 202
    [Misc] Mac scan to ricoh MP 5004 or MP4054
    I need assistance if i can scan either through ftp or smb to mac on ricoh mp5004 or mp4054?
    thanks.
    • 37240
    Re: Mac scan to ricoh MP 5004 or MP4054
    Apple quit including Samba in OSx a few years back. Samba is the implementation of SMB used by Apple and Linux.
    There are a number of FTP options for Mac OS that can be downloaded if you wish to go that way.
    Another option that should work are scan to a memory device.
    I don't know if WIM can be use with Mac or if it is only for Windows. If it can be accessed then you can scan to the internal document server and use WIM to retrieve the file(s).
    • aviso66
      • Dec 2012
      • 202
      hi, thanks for the info. what kind of ftp software do i need to download?
      • 8T2
        • Aug 2015
        • 257
        I know some of my colleagues use FileZilla when they need to and its free. But I'm sure there are many alternatives around
        Sent from my WAS-LX1 using Tapatalk
        • Brianneoe
          • May 2015
          • 318
          Make sure all the firmware is up to date. On some older MFPs I needed to telnet into the MFP and change the SMB Client auth to a 1 or 2.
          On the Mac go to the Apple icon on the upper left and select "System Preference. Go to "Sharing" and check on "File Sharing" Go to the "Option" tab on the same page and check on "Share files and folders using SMB"
          Under "Account" make sure that person [the admin] is checked "On"
          You will go back to this page after you create the share folder to verify that the folder is listed as a Share with Everyone set as Read\Write.
          1-Create your scan folder by going to "Go" at the top of your tool bar and then click on your "Home" icon and create your Folder there.
          2- Right click the folder you just created and click on "Get Info" Select "Shared folder"
          3- In the Get Info page you will need to unlock the lock icon on the bottom with the log-in admin rights.
          4-In Sharing and Permissions select "everyone" and change it to "Read & Write"
          The SMB path will be the same as a PC. \\NetBIOS Name or IP address\folder name.
          This works with OS 10.13 thru 11.1
          Good luck.
            • 29790
            Hilarious now you like FTP
            Yes third party apps for FTP scanning to Mac's you have to purchase I don't think there are any free one's.
            Best options is scan to email or scan to a Windows machine and file sharing or scan to a shared NAS drive.
              I don't have any problem with SMB scanning on a MAC. There's plenty of videos out there of how to set it up for a Kyocera. Not sure about Ricoh.
              PS - Mac only uses SMB2 or higher.
                • 37240
                Wake up idiot and read all of what I commented. You will see that I said "if you wish to go that way."
                  • 37240
                  If you really want to use FTP then launch your browser, go to your preferred search engine and search for 'ftp for mac os.'
                    • 29790
                    Still Hilarious
                    Always a if customer always has the choice
                    YOU can only recommend and use best practices.
                    Why don't your share YOUR previous thoughts and comments on FTP?
                      • 37240
                      Still Hilarious
                      You mean the fact that you are the only IT person that recommends FTP. Every customer IT that I have worked with over the years, and there have been many, consider FTP a security risk on their networks. And you are the one who is hilarious and still an idiot.
                        FTP has been discussed so much that I did a little homework for myself.
                        FTP is considered an insecure protocol because it doesn't use encryption.
                        However, Filezilla can be connected to use FTPS which is considered secure because it uses encryption.
                        My 2-cents, for what it's worth.
                        How to connect with FTPS using Filezilla – Support
                          • 29790
                          Thats because YOU don't know what your talking about.
                          You dont know the difference between internal ftp and ftp external.
                          Glad I could I could help explaining to You again.
                          Again its an option a solution a fix that's what real technical people do.
                            • 8131
                            thanks.
                            Yes you can scan VIA SMB same as you can with Windows.
                            I have a MAC at home on OS High Sierra I scan to it on a MP C407.
                            • marvin-vegan
                              Product specialst support
                              • Jan 2021
                              • 46
