imc3000
  • tonerhead
    • Sep 2009
    • 582
    imc3000
    New machine that has been a hanger queen for a while. Hit power switch, starts loading, then goes into shutdown before anything happens. Since it is new but a hanger queen, Ricoh will not warranty any boards we order for it. Any quick thoughts? We are thinking controller?
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
    • 37532
    Re: imc3000
    Sounds like an out of box failure to me. Get ypur regional rep out to look at it.
    Have you tried powering it up with the front door open? That might allow you to get into SP mode and check SC code history.
    • tonerhead
      • Sep 2009
      • 582
      Re: imc3000
      Yes we have. Thanks for the reply. Being this machine was a floor model for about 11 months, Mother Ricoh is saying it is not new and doesn't consider it out of box failure. I can somewhat see their point, but it has zero miles, and was not powered on for 11 months. It was a floor model, turned off until a customer wanted a demo.
      • Juggy
        Technical Support
        • Sep 2007
        • 101
        Re: imc3000
        It is controller failure. There is an similar RTB on the same. Check the serial number of your Device if it falls in the list.
        • copier tech
          • 8172
          Re: imc3000
          If you get a message on the screen saying 'shutting down' before any of the icons etc load.
          I had this exact issue, it was caused by the power supply that inputs the 5V to the controller.
          • tonerhead
            • Sep 2009
            • 582
            Re: imc3000
            Thanks for the replies. I found out that a co-worker has ordered a controller for it. The copier falls beyond the cutoff for the controller, so I am in agreement that it might be the power supply. Another thing I thought of might be the power switch on the front. I had one of those go bad once, and it had me going in circles for a while. I remember calling support on that and support had me unhook switch and momentarily shorting wires to start. It started right up.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Re: imc3000
              Doesn't matter if the serial number range is in the RTB they will warranty also unless you a very basic dealer you should get 12 months on boards also zero meter and covid tell them to sort it
              Regards Mark
              • tonerhead
                • Sep 2009
                • 582
                Re: imc3000
                Unfortunately the serial number is not in the defective range of the RTB. The problem is that the machine was delivered 11 months ago, zero miles, never sold. Our Ricoh rep says no warranty as copier is nearly a year old and they offer 90 day warranty. I suppose they have to draw the line at some point. Would it still be new if we haven't sold it after 2 years, 3 years? It just bites that with all that is going on, we are stuck with a machine that doesn't work with zero miles.
                  • 37532
                  Re: imc3000
                  I was thinking that the US warranty was only 90 days. But being retired for over 3 years it could have changed.
                  • copier tech
                    • 8172
                    Re: imc3000
                    If you have a controller on order it will be worth fitting as a test, if it doesn't fix the issue I hope you can return it?
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      Re: imc3000
                      Ricoh is being out of order what about the dealers that buy 20 machines from ricoh for better price then keep in there stock for a year before they sell if got zero mileage on it I would give them a right mouth full.
                      Regards Mark
                      • tonerhead
                        • Sep 2009
                        • 582
                        Re: imc3000
                        I know. Our mgmt is climbing the Ricoh tree right now on it. Shake enough branches and eventually someone will give in.
                        • tsbservice
                          Field tech
                          • 8020
                          Re: imc3000
                          So dealer buy from Ricoh like mga said ie bulk of 20 machines and after 91 days of purchase date one machine being brand new installed and dead...and that isn't DOA? Sounds crazy but I may misunderstand something.
                          • tonerhead
                            • Sep 2009
                            • 582
                            Re: imc3000
                            Apparently true, they are within their rights to do so. Doesn't make sense to me either. We are shaking the tree to see what falls out though.
                            • tsbservice
                              Field tech
                              • 8020
                              Re: imc3000
                              Good luck then, from ethical point the truth is on your side sadly big corporations always dictate interpretations of truth.
