RICOH MP W6700 Streak, Line corner of page when printing more
  • Like1mS
    • Jun 2018
    • 23
    Hello,
    Client has MP W6700, so far to fix the streaks we changed fusing unit maintenence parts, pressure roller, separation fingers etc.
    And everything was ok. After a while client called that streaks appear only when printing more pages at once. Pictures attached.
    Drum unit, cleaning blade was also changed not that long ago. Im looking for information what else could i check. Appreciate all answers. Thanks.
    Picture attached.
  • luca72
    • Oct 2017
    • 1779
    Re: RICOH MP W6700 Streak, Line corner of page when printing more
    Originally posted by Like1mS
    Hello,
    Picture attached.
    hi, i don't know how much the w2201 mpc is equal to yours, but i hope this video i had made months ago can help you
    regards
    p.s. read well description
    Ricoh MPCW2201 Manual cleaning for unlock head clogged After lockdown - YouTube
    "I'll be back"
    • Like1mS
      • Jun 2018
      • 23
      regards
      Thanks for answer, unfortunately its laser printer black and white.
      • luca72
        • Oct 2017
        • 1779
        it may work however, there are residues that the automated cleaning mechanism over time cannot clean
        "I'll be back"
        • Like1mS
          • Jun 2018
          • 23
          The technique showed in video is for inkjet printers like W2201, W6700 is laser printer, doesnt have a printhead.
          What exactly do you have in mind ?
            you addressed things other than the dev unit.
            • luca72
              • Oct 2017
              • 1779
              I'm sorry, I hadn't seen it, however I took a quick look at the manual, it would seem a leak of developer bias, or a bad ground drum, in my opinion there is some problem with the developer powder to replace or drum ground, try to clean
              "I'll be back"
                • 37491
                Hello,
                Picture attached.
                For the drum unit, cleaning blade, how long ago IS the "not long ago" that you mention? The line looks like what can be caused by a dirty charge roller or a nick or debris on the cleaning blade.
                • Brianneoe
                  • May 2015
                  • 318
                  If the streak moves I would replace the main charge unit. If it is always at the same area check the upper guide plate before the fuser unit. The upper part of the guide plate may have collected toner over time and is marking up the paper when it buckles before it enters the fuser unit.
                  I have a few of these out there but none with over 100K LF.
                  • esoxgreg
                    • Nov 2019
                    • 12
                    Probably a worn out Hot Roller. If you take that copy and put it up against the fuser Hot Roller, I bet you'll see wear lines on the roller. You don't have to remove the fuser section, just open the doors and put your print near the dark hot roller.
