Lanier LW 310 / aficio 240W error SC300-01 does this need a service mode reset?
  • tonerjockey
    • Apr 2014
    • 567
    Hi guys, hope you are all safe this new year.
    i am having an issue with this unit. wide format. customer had two issues. it had a waste sump full indication which i dumped. then it shows an error SC300-01. i pulled the drum unit out, blew out the charge and transfer corona units. they look good. same thing.
    i searched for a long time in service mode trying to find a clear error code. i looked for SP5-810, but that number isn't there.
    also tried service mode and hitting SP and rebooting.
    i am wondering if this error code needs a service mode entry to clear it, or if it resets assuming that the issue is gone, by s a simple reboot?
    the code is for a charge corona feedback voltage loss.
    has anyone got any experience with this code?
    thank you very much for any input or advice.
    Jim
    • 37478
    Re: Lanier LW 310 / aficio 240W error SC300-01 does this need a service mode reset?
    Only requires cycling the power once the cause of the actual cause has been repaired. From Goose's Guide
    check or repl. toner door switch
    Charge corona ouput error: Defective CGB power pack
    Charge corona ouput error: charge corona assembly defective
    Charge corona ouput error: Clear NVRAM
    The corona may look fine but there can be micro fractures in the plastic end blocks that will cause leakage to ground.
    • DRichard
      • May 2008
      • 482
      I agree with slimslob about the likelihood of tiny fractures etc. As old as these are, I would try to replace the entire assy, although individual parts were available originally.
      "Enjoy every sandwich."
      -- Warren Zevon
      • tonerjockey
        • Apr 2014
        • 567
        Thanks guys. the last line said clear NVRAM. is that required to clear this fault code, or is it just the long list of possible causes of the initial code?
        anyone have a source for charge corona etc??
        thanks so much.
          • 37478
          thanks so much.
          Many items in Goose's Guide are things that some other tech at one time has had to do. Clear NVRAM is a last resort operation when nothing else seems to work.
          • tonerjockey
            • Apr 2014
            • 567
            ok, that is what i thought.
            thank you.
            • Brianneoe
              • May 2015
              • 318
              Dont do a NV clear with out backing up the NV in SP5824. 99 times out of 100 the problem is the end blocks are shorting out. The charge unit part # is AD00 4103
              • tonerjockey
                • Apr 2014
                • 567
                ok thank you.
                do replace the wires as well? is it hard to keep them from getting all tangled up and kinked??
                i was told by Hytec that there were pico or surface mount fuses on the charge power pack. i pulled the board and found none. i tested the output and then it started working. so i fully assume that the charge end blocks are going out.
                have a nice day, Jim
                • luca72
                  • Oct 2017
                  • 1774
                  ok thank you.
                  you can try an old trick, to make sure they are really those, give a nice brushstroke of bleach / liquid concealer, on both blocks, even inside, and then let them dry well, and try. sometimes even without micro-fractures, the plastics of the blocks are chemically cooked, years ago they even changed color, they went from yellow to orange here corona sc codes usually do not need to be deleted.in case you try, let me know if it worked.regards
                  "I'll be back"
                  • tonerjockey
                    • Apr 2014
                    • 567
                    ok, great idea. yes, back in the day the amperage was much higher, and you could see and smell the burning trace. but that was way back when the HVPS was a separate box, not small transformers on a small board inside. gets the job done, but harder to diagnose.
                    be safe.
                    • tsbservice
                      Field tech
                      • 8007
                      Yes good idea. Another trick I used in Toshibas when they had Voltage leaks through end plastic terminals is to simply cut 4 small pieces of electrical tape and put them between 2 corona wires(T and S) and terminals in places when corona touches plastic terminals. Worked every time for me.
                      Good luck
                      • tonerjockey
                        • Apr 2014
                        • 567
                        30 years ago i tried the electrical tape between the end block and the aluminum housing. but never had any luck.
                        this machine is 20 miles away for me, and the gas support springs are shot.
                        i took the power pack out Friday, looked for any surface mount fuses. found none. tested the output, even felt it thru my old leads. it was listed at 6250 volts. then reconnected the charge and it suddenly came to ready and printed nicely.
                        so i fully expect it to code out again. and when it does, i will replace the assembly. don't want any issues.
                        thank you, Jim
                        • luca72
                          • Oct 2017
                          • 1774
                          thank you, Jim
                          let's say, it's been a couple of years that I have no problems with the corona (LOL) .. maybe because I replace it when it is not too old (?) if that family of sc codes happens to me, I already go there with a completely rebuilt unit, however I would be curious to try this:
                          guarantee 48k volts / mm !!
                          "I'll be back"
                          • tonerjockey
                            • Apr 2014
                            • 567
                            back maybe 20 years ago, there was a couple places that sold things for us techs. one might have been called tech aid? i had found some really useful tools and liquids for cleaning etc. there was a product called??? something dope or what ever. it was a thick black goo or paste in a bottle with a brush.
                            it was some electrical insulator that was supposed to help this corona end block problem. it may have been for tv high voltage fly back circuit.
                            and maybe it would work with today's HVPS better, since they may have much lower amperage's?
                            i may still have it somewhere, but it never seemed to work for me.
                            • tonerjockey
                              • Apr 2014
                              • 567
                              I remember now.
                              It was called corona dope
