Ricoh 8120s pro Dirty paper edges
  • socoolone
    • Sep 2015
    • 20
    I just inherited a 8120s with only 800k on it. Did a full pm on it runs great but the edges of the paper are dirty. Cleaned the paper path and its good for about 1000 prints then it comes back i cant seem to find where the toner is coming from. any help is appreciated.
  • DRichard
    • May 2008
    • 482
    Re: Ricoh 8120s pro Dirty paper edges
    ALL edges affected or just the lead edge maybe?
    "Enjoy every sandwich."
    -- Warren Zevon
    • DRichard
      • May 2008
      • 482
      Check out the Troubleshooting section of your Service Manual. It addresses something like what you are describing. Good luck!
      -- Warren Zevon
      • anothertech
        • 1766
        Pull out the ITB assy. and take the lower plates off. Are they real dirty? Clean them and check to see if the front and rear edges of the ITB are hanging down, the belt stretches and hang low on the ends, touching the plates.
        • TonerMunkeh
          Professional Moron
          • 3865
          Check the filters and the ducting in the back. Were they replaced at PM? If not, toner puffing from the dev unit can cause this. If they are fine, there is a duct under the dev unit that fills with toner when the dev unit fails.
          Hit it.
          • socoolone
            • Sep 2015
            • 20
            Leading and trail edges toner seems to collect on the belts before the fuser
            • socoolone
              • Sep 2015
              • 20
              thanks i will check the filters and the duct
              • TonerMunkeh
                Professional Moron
                • 3865
                If you haven't changed them, do all 4. Two in the toner duct and two at the top right hand side.
                Hit it.
                • socoolone
                  • Sep 2015
                  • 20
                  Wow the ducts were so dirty i blew them out with air and cleaned the filters and ordered new fans and filters thanks for the help that is not in the service manual. You rock i would have been chasing that forever hopefully this fixes the problem
                  Thanks again
