Ricoh MP C4503
  • jper34
    • Sep 2011
    • 225
    Ricoh MP C4503
    s/c370-2,370-3 codes-I would clean ID sensors, and it would clear up, but now it's returning, alot more...I have replaced the ITB, an no change, any suggestions appreciated...thank,
    Jaime
  • Gift
    • Mar 2011
    • 2459
    Re: Ricoh MP C4503
    Is the image density OK on the transfer belt for all colours? You can interrupt the print process and check the image on the belt - In case it is looking OK you might have a faulty ID sensor but that's pretty rare. Also check the corresponding SPs with the birth sheet in case the value went of the roof during a bad calibration run.
    • copier tech
      • 8192
      Re: Ricoh MP C4503
      Jaime
      What are your PCU & PCDU PM life at?
      Update the firmware & check your cyan PCDU.
      SC370 Errors.pdf
        • 37556
        Re: Ricoh MP C4503
        You may need to replace the ID sensor board.
