SC672
  • antoney suresh das
    • May 2011
    • 101
    [Error Code] SC672
    HI Guys,
    I tried to check a mp 9000 IOB board on a running Mp1100 i found that the 9000 IOB BOARD was indeed defective when i returned the 1100 board back to the original machine it's
    throwing up a SC672 error can some one guide me on this how to release this error.
    thanks
    • 22808
    Re: SC672
    Originally posted by antoney suresh das
    HI Guys,
    thanks
    Ricoh links several boards together by Ser # go back to the manual and see how to re input the ser #
    • copier tech
      • 7934
      Re: SC672
      HI Guys,
      thanks
      SC672 is a generic controller error & since you have been removing & swapping boards, fit the original boards back & double check all the connections are correctly seated, most likely one is loose.
      SC672 Controller Start Up Error.pdf
