MPC2004 Scanning when out of toner.
  • soaponarope
    Pat McGatt
    • Nov 2020
    • 30
    [Misc] MPC2004 Scanning when out of toner.
    I have a customer who says scanning is not working as one of the toners is empty (they are awaiting delivery). Is this the case on that machine, I would have thought you could still scan? I know you can on other manufacturers machines.
    • 37379
    Re: MPC2004 Scanning when out of toner.
    Does it have a results report for either scan or fax that is pending to be printed? Has the memory filled up with faxes that are waiting to print?
    • copier tech
      • 8131
      I just checked on an MP C407 with the toner removed it let me scan OK.
      • soaponarope
        Pat McGatt
        • Nov 2020
        • 30
        Hi folks, thanks for your efforts. I have just discovered there is a limit of 200 scans then it won't let you do anymore.
        • copier tech
          • 8131
          Good to know, thanks.
          Maybe if the client powers off/on the machine it will reset that 200 scan limit count!?
          • marvin-vegan
            Product specialst support
            • Jan 2021
            • 46
            Just switch this setting to "Do not print, delete the oldest"
            • ThePomqueteer
              • Sep 2016
              • 73
              Is it possible the scanner journal is full and set to Disable Send?
              Check User Tools - Scanner Features, General Settings and Under Print and Delete Scanner Journal according to the manual there should be 3 options:
              Up to 250 transmission results can be checked on this machine. If the stored transmission results reach 250, specify whether to print the delivery journal.
              Depending on the security settings, the transmission journal may not be printed.
              • Print and Delete All
                The transmission journal is printed automatically. The printed journal is deleted.
              • Do not Print: Delete Oldest
                Transmission results are deleted one by one as new results are stored.
              • Do not Print: Disable Send
                Transmission cannot be performed when the journal is full. You can transmit if you press [Print Scanner Journal] to print the journal or press [Delete Scanner Journal] to delete the journal.
                I would check this and if its set to Disable Send you should be able to print/delete the Scanner Journal manually
              • eccelobo
                • 113
                You could also set momentaneously SP3100-001 to "1".
                Good luck!
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  I think it varies model by model, even within Ricoh.
                  I had the same issue 5 or 6 years ago with.
                  I don't remember the model number, but at the time we did a pretty thorough search for an answer, and found none.
                  We called tech support as well, and were told we had to have toner in it. Absolutely no surprise there.
                  We were out in the boonies at the time, and the nearest account we could borrow any from was over an hour away.
                  In this case, the (B&W) machine had the AutoStore client installed, and refused to scan until we fed it some yummy toner.
                  • mikadonovan
                    • May 2008
                    • 2931
                    I suppose you could disable toner end detection to keep them going until they get a new cart, if that is what's causing the problem.
                    NEVER ASSUME ANYTHING
                    • copier tech
                      • 8131
                      This has already been suggested.
                      • mikadonovan
                        • May 2008
                        • 2931
                        OMG, 2 techs suggesting the same possible fix, the worlds coming to an end! WTF. What a waste of a post.
                        • copier tech
                          • 8131
                          Yes it was.
