Ricoh MP2851 can receive faxes but not send
    • 37556
    #16
    Re: Ricoh MP2851 can receive faxes but not send
    Originally posted by KeviM
    Thanks for this. Should be a big help on Monday.
    Btw, that call you mentioned where the phone line was bad, no dial tone and fax board was bad, it must have been hectic
    Yeah, with the bad phone line I really could not test the machine. After the phone company fixed the line I got a call back. Then I discovered that the fax board was not detecting dial tone. Luckily I had a machine in the office I could borrow a fax board from.
    • KeviM
      • Oct 2019
      • 327
      #17
      Hectic. .. if you don't mind me asking, what did the customer say about the problem taking so long to resolve?
        • 37556
        #18
        The biggest delay was getting the phone company out. The customer also had 6 other machines in the main office and 3 out in the machine shop they could use.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          #19
          When I serviced faxes, I always carried a cheap (under $10) phone with me to test fax lines. A quick and dirty tool.
          A few years ago, I found a very inexpensive butt set online that was about $15 dollars or so, (good ones are expen$ive), and it had alligator clips to make it easy to connect, as well as the standard RJ-11 plug and jack.
          More recently I moved on to supporting fax servers. While quite a few did not use standard analog lines, the majority of them still did.
          I later picked up a USB-connected modem for my notebook (about $35, as built-in modems disappeared quite a while back), and that was the best investment of all. It came with some really awesome fax software. That allowed me to literally carry my own fax machine with me that could send and receive. Certainly not conclusive, but it helped me out tremendously. Highly recommended. (BTW...Don't get carried away with any fancy features. The more generic, the better.)
          • KeviM
            • Oct 2019
            • 327
            #20
            Same here in South Africa. The phone company can take anywhere from 1 week to 6 weeks to come out and in that time the customer is going crazy.
            • mikadonovan
              • May 2008
              • 2931
              #21
              I still do, and used it at least once last year.
              NEVER ASSUME ANYTHING
              • KeviM
                • Oct 2019
                • 327
                #22
                I'll have to look into getting some those. It would be a good investment
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  #23
                  Originally posted by Chicko
                  Hello
                  My client has a Ricoh MP2851. The machine is working fine and has been doing so for many years. In the past 2 or 3 days the client says that they can receive faxes but not send.
                  I tried calling the Ricoh fax machine from a normal telephone and I do get a fax start tone
                  Does anyone have idea why ?
                  Thank you
                  Could be wrong fax cable they not all the same just in case customer has changed
                  Regards Mark
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    #24
                    Silly question, but here goes.
                    Is that model machine sensitive to the polarity of the phone line wires (tip and ring)?
                    I think most modern machines technically are, but they auto-sense and reverse it internally.
                    That used to be a HUGE issue a few years back, where the polarity being reversed would not allow the machine to send, but receive was OK.
                    A lot of times, phone line work would get done, and the polarity could get switched, either accidentally or otherwise. It used to happen a lot.
                    I may be dating myself, but I figured I'd throw it out there.
                    • KeviM
                      • Oct 2019
                      • 327
                      #25
                      Not sure ... I know everything was working fine up until about 3 days ago. So I'm assuming it was correctly connected up until then. I'll have to double-check that when I get to the customer.
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        #26
                        Also, check the voltage between the two.
                        It should be about 48 VDC on-hook, and about 7 VDC or less off-hook.
                        When ringing, about 90 VAC.
                          • 37556
                          #27
                          And it is still correctly connected now. Otherwise it not only would not be sending but also not receiving.
                            • 37556
                            #28
                            That would be true when connected to most analog phone lines. However if connected behind a PBX, analog or digital KSU or VOIP to analog line converter that value could be 24 VDC on hook with off hook value as low as 5 VDC.
                            • sandmanmac
                              • 3983
                              #29
                              Must admit, i kind of just breezed through a lot of the replies, but a couple of things I picked up on is that you mentioned in your first post that you called the fax from a regular line and got a fax tone, "why"?......That's always been the case, the machine will/ should pick up and try and receive.
                              2nd......Since very few customers even using fax anymore, I stopped carrying a cheap handset that's been mentioned earlier, but if you press "on hook" and don't hear a dial tone, in order to isolate the problem, I simply disconnect a handset from one of the office phones, and plug it directly into the wall jack. No dial tone? It's Not a machine problem.
                              • KeviM
                                • Oct 2019
                                • 327
                                #30
                                That's what I'll need to check when I get there on Monday.
