Ricoh MP2851 can receive faxes but not send
  • KeviM
    • Oct 2019
    • 327
    #31
    Re: Ricoh MP2851 can receive faxes but not send
    Originally posted by sandmanmac
    Must admit, i kind of just breezed through a lot of the replies, but a couple of things I picked up on is that you mentioned in your first post that you called the fax from a regular line and got a fax tone, "why"?......That's always been the case, the machine will/ should pick up and try and receive.
    2nd......Since very few customers even using fax anymore, I stopped carrying a cheap handset that's been mentioned earlier, but if you press "on hook" and don't hear a dial tone, in order to isolate the problem, I simply disconnect a handset from one of the office phones, and plug it directly into the wall jack. No dial tone? It's Not a machine problem.
    I will definitely be doing that when I get there on Monday. I'll disconnect the line and put a normal phone in. And run some tests like dialing out from there.
    • KeviM
      • Oct 2019
      • 327
      #32
      Went to the check the machine today. After doing some testing and checking for dial tone and trying to fax out the fault was found. A damaged telephone cable which connects from inside the PABX system to the machine for faxing (just like a standard telephone cable with a rj11 connector on it ). Unfortunately I didn't have access to the internals of the PABX system to change it.
      PABX guys should be in 1 of the days to sort the fax line out.
      Thank you to everyone for your help and advice.
