Faxing Aboard
  • lloydy83
    • Feb 2017
    • 8
    [Misc] Faxing Aboard
    A customer is asking to fax abroad to Germany once in a while off a Ricoh machine. But it is not transmitting, Is there any bit switches or any SP modes that need setting up or have I completely just missed something simple??????
    Re: Faxing Aboard
    do they have phones lines capable of faxing to that country?
    have you checked the manual for international faxing?
    • copier tech
      • 8174
      Re: Faxing Aboard
      You need to have the fax address book numbers programmed with the +44 code etc.
      A simple test press on hook, dial your international number do you hear a fax tone? if yes pop your fax in the DF & press go.
      And as always make sure the firmware is the latest.
      • Debs1964
        • Oct 2010
        • 1693
        Re: Faxing Aboard
        Add the destination number to the address book, using (+49 for Germany), and select International TX mode for that entry in the address book, if International TX mode is not an option, try changing Fax SP 1-101-001 bit 0 from 0 to 1
        There are 10 types of people in this world, those who understand binary maths and those who don't
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Re: Faxing Aboard
          If there's one thing dying off faster than faxing in general it's international faxing.
          It looks like your're in Wales, and I don't know what your rates would be, but in the US you'd be eaten alive by the charges.
          Keep in mind that you will almost certainly be charged for calls that connect and fail, right along with the successful ones. I once had a customer with line problems (local to their area) that went ballistic when they got their phone bill for all the failed faxes to various locations in Europe. Somehow, it was our fault.
          Ask the customer if they know what it's costing them.
          This will be the best reason to switch from faxing to scan to email you may ever find.
