RICOH MPCW 2201 sp error code SC 672-11
  • Andy74
    • Feb 2021
    • 25
    [Error Code] RICOH MPCW 2201 sp error code SC 672-11
    Dear Guys!
    Has anyone had such a case?
    Please help me
    Thanks for any info
    Re: RICOH MPCW 2201 sp error code SC 672-11
    Originally posted by Andy74
    Dear Guys!
    Please help me
    Thanks for any info
    guess you didn't search CTN MPC 3003 SC 672-11
      • 37657
      Common error code across multiple models. After the machine was powered on, communication between the controller and the operation panel was not established, or communication with controller was interrupted after a normal startup. Frequently caused by a loose by defective communication cable(USB) between the controller and operation panel.
      • Andy74
        • Feb 2021
        • 25
        Thank you Will look for this procedure
        • copier tech
          • 8238
          Dear Guys!
          Please help me
          Thanks for any info
          Here's the bulletin, but its not much help.
          SC672-11.pdf
          • darwinabad
            • Jun 2014
            • 10
            Hello friends, any solution at this time? I suffered the same problem and changed the controller, operation panel, cables, power supply, etc. etc. And I still have the problem, please some help
            • copier tech
              • 8238
              Here's an updated bulletin & troubleshooting flow chat that may be of assistance.
              SC672-xx.pdf
