Ricoh mpc5503 (Black Strip Lines and shadows)
  • Pixtech Frameworks
    • May 2020
    • 237
    Hi Everyone,
    I have a customer Ricoh mpc5503 that prints black strips lines and shadows.
    I've LCU Polygon box etc to no avail.
    Pls does any one have an idea what could be the problem?? Attached its a copy of printout and color pattern.
  • copier tech
    • 8121
    Re: Ricoh mpc5503 (Black Strip Lines and shadows)
    Originally posted by Pixtech Frameworks
    Hi Everyone,
    From your sample it simply looks like the black PCU is worn out. What is the PM life on?
      • 37052
      BAd drum, dirty charge roller, excessively worn lube bar.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Black pcu
        Regards Mark
        • sandmanmac
          • 3973
          Hi Everyone,
          Agree with everyone else.
          I's unusual to say the least that you'd start by replacing the Laser unit for an image quality problem like this
            +1 start with the cheapest parts first...
            • tsbservice
              Field tech
              • 7940
              Hi Everyone,
              So bad. Isn't that viewable when you look at black drum?
                • May 2020
                • 237
                30k copy, 10k print.
                Drum and PCR was changed recently. After it was installed, it came out the strips lines
                  • May 2020
                  • 237
                  A new opc drum and PCR.
                    • May 2020
                    • 237
                    30k copy, 10k print
                      • May 2020
                      • 237
                      I didn't replaced. I only cleaned with cleaning brush.
                      • davel
                        • Oct 2011
                        • 1089
                        Genuine parts or cheap compatible crap?
                        • copier tech
                          • 8121
                          You are clearly on a budget.
                          Swap the black charge roller with one from say the yellow PCDU & see if the image quality fault swaps to yellow.
                            • 37052
                            I get the impression that he doesn't know how to access the charge roller. Judging from his profile he is still an apprentice.
                            • copier tech
                              • 8121
                              Yes, anyone who would replace the laser first for black lines clearly doesn't have a clue!
