MP 3054
  • thurmmy
    • Aug 2016
    • 102
    MP 3054
    I am having a bit of trouble getting into service program. I can get into the main service program, also factory mode, but it will not go into the individual program, ie. copy, printer, scanner, fax, portions. Not grayed out. Just beeps. Hmmm. What up with this?
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: MP 3054
    Unplug from network blue light must not be flashing
    Regards Mark
    • thurmmy
      • Aug 2016
      • 102
      Re: MP 3054
      Not plugged into network. In shop.
      • KeviM
        • Oct 2019
        • 324
        Re: MP 3054
        Hi, just wondering, is the touch screen panel functioning properly?
        Could be damaged or shorting out
        • thurmmy
          • Aug 2016
          • 102
          Re: MP 3054
          Yes, it is. It is actually from another machine. The one I am having problems with had the 672-11 code with the op panel non-responsive at all, buttons or otherwise. I am able to get into the firmware update box but that's it. Am I dealing with a controller board issue? I was just recently repaired by Hytec.
          • luca72
            • Oct 2017
            • 1784
            Re: MP 3054
            hi, I would not like to make a stupid observation, but, it is not that you have java activated? as soon as you turn on the machine it may have biblical times before it allows you to advance in the various sp menus ... if one does not keep it in mind it could turn off and on again again ending up in a psychological loop
            "I'll be back"
            • CopyBats
              • Aug 2011
              • 147
              Re: MP 3054
              Check if the machine has hard drive.
              Go in copy screen ( not sp mode but copying screen) and see if double sides original is grayed out
              If it works, don't touch it.
