404 page not found
  • pgotocom
    • Feb 2021
    • 1
    [Misc] 404 page not found
    I have a problem with Ricoh MP301SP in we interface it shows error with 404 not found machine is available on the network and PC printing is ok but can't access web gui any body advise.
  • 8T2
    • Aug 2015
    • 257
    Re: 404 page not found
    Have you tried connecting dierectly to device with LAN cable and bypassing network? You sure the PC and device are in the same IP range and Subnet?
    Sent from my WAS-LX1 using Tapatalk
    • satins
      • Feb 2021
      • 89
      Almost all medium and enterprise engine have a SP setting to enable/disable NIC and USB. I am not sure about this particular model but you can check it in the Service mode.
      Ensure it is set to 1:enable
        • 37532
        This can happen if a device certificate has been improperly created. To check try accessing as https instead of http.
        • copier tech
          • 8172
          Have you tried another browser?
          Also update the firmware.
