Smart panel version 2 & higher
  • tjvincent
    • 280
    I'm trying to set up 2 separate Icons on the smart panel, 1 would default to scan to email and the other scan to folder.
    Is this possible ?
  • sandmanmac
    • 3981
    Re: Smart panel version 2 & higher
    Is this possible ?
    While I don't know the answer to this, I'm astonished that it's apparently far too much effort for your client to use the Classic App and simply switch between folder and email
    It's LITERALLY 1 extra touch
    Just saying........
      • 8190
      Just saying........
      .. it is one extra step performed many times per day during a five year copier lease.
      Customizing the LCD improves customer satisfaction and is easy to do on competitive models like Toshiba where the LCD panel is basically an interactive tablet.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Is this possible ?
        Yes you can it's in the user manual quite easy to do
        Regards Mark
        • tjvincent
          • 280
            • 37472
            The default for the Classic Scan function can be set in User Tools. The only time and extra step is necessary is when you don't want the default.
              • 37472
              That is because they do not exist as separate functions. You can use the the Classic Scan default for one. For the other you have to save the settings as one of the "Program" keys and then put that "Program" key as an Icon on the Home Screen.
              • copier tech
                • 8142
                The classic scanner, scanner & quick scan apps all use the same default setting as either email or folder.
                You cannot have one app defaulted to SMB another to email they all need to be the same.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Can't you save on program keys
                  Regards Mark
                  • fshead
                    • 2376
                    THAT REALLY HELPS when he is asking about ricoh not toshiba..........
                    i guess things are slow there
