Mp 4054 Random jams in J18, J19 and J20
  • Codex
    • May 2008
    • 704
    Hello guys
    I have a Mp 4054 that makes random jams in j18 (Fusing Entrance), J19(Fusing Exit:On) and J20 (Paper Exit:On), already changed fusing sleeve, but customer complains random jams, i never saw it with my eyes, but they are logged in the Smc report... Cleaned the exit unit but custumer still reports random jams... Any ideas?
    Inviato dal mio SM-G935F utilizzando Tapatalk
    Memento Audere Semper
  • luca72
    • Oct 2017
    • 1784
    Re: Mp 4054 Random jams in J18, J19 and J20
    Originally posted by Codex
    Hello guys
    it happened to me on a 2503 (which has almost identical paper exit unit) to replace the paper exit unit, honestly I haven't had time to look at it yet, but I think it's some defective sensor, in my case it did it in duplexing, but if the other sensor was faulty, it would have done so in simplex
    "I'll be back"
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Hello guys
      Did you replace just sleeve or oem new sleeve assy
      Regards Mark
      • Codex
        • May 2008
        • 704
        Only sleeve, but i tried entire fusing unit from another machine... But customer still report jams
        • Zeldaman
          • Mar 2011
          • 946
          Hi there!
          My 2 cents on the paper-exit-unit. Had this issue on some machines. The parts were not formed out properly at the manufacturer, but installed by RICOH.
          After some times they get curved through the heat from the fuser and jams apear randomly but often.
          Hope this will help.
          Greetings...
          • Codex
            • May 2008
            • 704
            Originally posted by Zeldaman
            Hi there!
            Greetings...
            Changed entire exit unit... But customer still report random jams...
            • luca72
              • Oct 2017
              • 1784
              nothing, at this point you should try to replace the entire fuser unit with one of a machine that you know works, it could be the plastic guides that when they heat up start to deform, there was a bulletin on the 3003, I would not like to do you find the same thing, the paper, still whole or torn?
              "I'll be back"
              • Codex
                • May 2008
                • 704
                The problem is that i never saw a jam in this machine, but there are jams in the log and tje customer reports it... I already changed entire fuser unit from a working machine.. But next day the customer called for jams... At my last visit i printed some service manuals to test the machine... No jams!... I'm gone mad
                • Gift
                  • Mar 2011
                  • 2459
                  Also check the door switches or "shake" the machine a bit while testing to see if they are ok. Back in the days door-jam related jams has been logged as "at power on" but that's not the case anymore, at least in some of the newer models we discovered that the units are capable of jamming without a proper logging in some scenarios.
                  • mlandry71
                    • Sep 2014
                    • 24
                    was this issue ever resolved?
                    • Codex
                      • May 2008
                      • 704
                      Yes! In my case it was the drum picker finger.
                      Inviato dal mio SM-S901B utilizzando Tapatalk
