MPC3502 scan to folder
  • gglee852
    • Mar 2021
    • 2
    [Error Code] MPC3502 scan to folder
    I scanned to the WIN10 folder via FTP
    I need to scan a piece of paper into a document
    Press # within 60 seconds
    Scan the next sheet of paper
    The first file is successfully transferred, and the second file will fail if scanned within 30 seconds
    A transmission error occurred during the second scan within a short period of time
    Nothing happened on WIN7
    Is there any way to check?
    • 37459
    Re: MPC3502 scan to folder
    Have the firmware on the MP C3502 updated to support SMB v2/v3 and stop using FTP.
    • copier tech
      • 8142
      What if you put the documents in the DF does it scan OK?
      As slim said update the firmware.
      • anhdangvui
        • Jun 2013
        • 4
        FIRMWARE MÁY PHOTOCOPY Hy vọng chia sẽ này sẽ giúp ích cho quý khách hàng và các bạn kỹ thuật. Chúc các bạn thành công trong công việc.
        • anhdangvui
          • Jun 2013
          • 4
          You can find the firmware here
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Update firmware be very careful where you download firmware from should only be available to credited service engineers with my ricoh login details
            Regards Mark
