MPC307 Airprint
  • GeorgeBest
    • Jul 2009
    • 516
    MPC307 Airprint
    Hi,
    Got this customer complaining that when his machine is in sleep mode he can't use the airprint function because the netwotk is not showing his MPC307.
    When active and coming out of the sleeping mode the machine is seen and ready for airprint.
    Is this an issue from the network or an adjustment in the machine?
    anyone?
    Thanks in advance
    gr George
  • copier tech
    • 8103
    Re: MPC307 Airprint
    Originally posted by GeorgeBest
    Hi,
    anyone?
    Thanks in advance
    gr George
    Update the firmware this was a known issue.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Re: MPC307 Airprint
      +1
      Regards Mark
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3945
        Re: MPC307 Airprint
        This seems to be a common problem across different manufacturers.
        I have a Brother laser printer at home, and I had the very same issue with it when I first bought it. A firmware flash fixed it immediately.
        I wonder if some specs for AirPrint changed a few years ago. I know that specs for PCL change from time to time...lotsa stories on that one.
