MP 301 SC670
  • stuuk
    • May 2017
    • 13
    [Error Code] MP 301 SC670
    Any ideas on this, SC670 relates to communication error between BICU and Controller, I ordered both boards, fitted controller, turned on and seen waft of smoke and burning smell from back, not sure whether it was from board or other component, I fit new bicu and old controller, back to sc670, have now ordered both bicu and controller to fit both at same time, i'm grasping at straws. Whilst on SC670 i can do nothing with it
    • 37532
    Re: MP 301 SC670
    Normally SC670 has to do with the physical connection between the 2 boards. Most Ricoh now use a USB cable for that and the cables have a history of failing.
    • copier tech
      • 8174
      Re: MP 301 SC670
      If you saw smoke it sounds like you put a connector on wrong.
      • stuuk
        • May 2017
        • 13
        Re: MP 301 SC670
        There is only one connector between the BICU and controller and that is a board mounted and soldered plug and socket configuration, you can't make a mistake joining them, the controller is pretty much sitting on top the BICU, linked with this strip connection
        • copier tech
          • 8174
          Re: MP 301 SC670
          He replaced the controller so I assume using the old NVRam, maybe this was fitted upside down.
          • stuuk
            • May 2017
            • 13
            Re: MP 301 SC670
            the nvram was checked and double checked before and after replacement, thank you for your reply's
