Ricoh mpc2003 error code 370-02
  • Mwammb
    • Aug 2025
    [Error Code] Ricoh mpc2003 error code 370-02
    Hi,
    Help me to solve this Error code 370-02 in RICOH MP C2003
  • copier tech
    • 8187
    Re: Ricoh mpc2003 error code 370-02
    Originally posted by Mwammb
    Hi,
    • Description:TM (ID) sensor calibration error (R) Regular reflection optical output voltage of the Front or Center or Rear TM (ID) sensor: Vsg_reg cannot be adjusted to within target range. Upper limit (SP3-320-013: initial value 4.5V) Lower limit (SP3-320-014: initial value 3.5V)
    • Causes:• TM (ID) sensor connector missing/ connection fault • TM (ID) sensor detection window dirt • TM (ID) sensor malfunction • Undulation in the ITB, or belt slippage
    • Code: SC370-03
    • Remedy:• Update the firmware. Remove image transfer unit, and check for TM (ID) sensor connector missing. If it is missing, reconnect it. • Check for dirt on the ID sensor detection window. If te detection window is dirty, clean by predetermined method (do not wipe dry). • Check the condition of the ITB. If undulation or belt slippage has occurred, re-install or replace the ITB. • If neither of the above have occurred, perform TM (ID) sensor replacement
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Hi,
      Clean all id sensors
      Regards Mark
