Ricoh Aficio MPC-305SPF
  • Elsayed Hamdy
    • Oct 2020
    • 2
    I did a really stupid thing , I did a Memory Clear All, I don't have a birth certificate I called for maintenance but everyone comes and play around and doesn't help me that much.
    So what i want is anyone have a
    Ricoh Aficio MPC-305SPF can upload it's birth certificate or the settings of the machine Please
  • JonManchester
    Technician / Shop Manager
    • Aug 2013
    • 103
    Re: Ricoh Aficio MPC-305SPF
    Open front door and there is a black plastic cover that pops off, usually the BC is in there.
    Live for something or die for nothing.
    • copier tech
      • 8172
        • 37532
        Certain SP settings are specific to certain parts like the laser diode units and the ID sensors. You're lucky on the laser units for the C305. The values are actually stored in memory on the diode units. There are SP modes that copy them to the engine, see the service manual on replacing the laser diode units. For the ID sensors those settings come on a sticker that comes with a NEW sensor assembly. If you do not have the BC or a recent non-default print out you may have to replace the ID sensor assembly.
        • Elsayed Hamdy
          • Oct 2020
          • 2
          I need it to set some settings not all settings like fusing temp settings laser settings is fine i need fusing temp settings
            • 37532
            All default fusing temp settings are are shown in the service manual.
