Fiery for Ricoh MP C4504
  • ABS tect
    • Sep 2013
    • 511
    Hey all, I have one customer that requests Fiery on their machine. They are still using their MP C4501 with fiery and wanted to get a MP C4504 with fiery as well.
    The 01 had an actual fiery unit attached to the base, upon doing some research for the 04 I wasn't sure exactly how or if the fiery is an option.
    Does the MP C4504 support fiery or just the MP C4504ex? Is it just a controller you can download? SD Card? If so could anyone point me in the right direction on how to install it on the machine?
    • 37532
    Re: Fiery for Ricoh MP C4504
    It is listed in the Product Support Guide only the guide does not use the term "fiery." I found it searching EFI, the company that makes fiery.
    Color Controller E-23C, EFI Controller, EDP Code 417486
    Since it is not in the service manual, installation instructions will most likely be included with the product.
    • ABS tect
      • Sep 2013
      • 511
      Thank you sir
      • copier tech
        • 8172
        Ask yourself this, does the customer really NEED a fiery/colour controller? Unless they use MACs & do a lot of graphic/PDF work these make little difference to an office copier.
        If they are using an old C4501 I doubt they need one on a newer model.
        • ABS tect
          • Sep 2013
          • 511
          I agree....and honestly I don't think they do. They just need good cq which the 04 will deliver. But in the off-chance they are hell bent on it I wanted to be prepared.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            • copier tech
              • 8172
              I would put the money towards a MP C6004 they would see a huge improvement over their old C4501.
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                The C4501 with a Fiery was a total nightmare, and the pair required constant attention.
                There were TONS of updates to be installed, and reimaging was a frequent occurrence. (I only had 2 of them in the field, and they both drove me nuts.)
                The newer models work MUCH better.
