Ricoh C3500a printer - No memory available at heap & stack size
+ More Options
Posts
  • jordy144
    • Mar 2021
    • 7
    Hello,
    One of my customers got a problem with one of our Ricoh C3500a printers. It seems that there is no memory available for the heat and stack size settings.
    Does anyone here knows what the problem can be?
    Thanks in advance,
    Kind regards,
    Jordy
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh C3500a printer - No memory available at heap & stack size
    Heap and stack settings are only available when there is a Java card installed.
    Hit it.
    • jordy144
      • Mar 2021
      • 7
      Thank you for your answer. We sold 5 Ricoh C3500 to them, and all of they report that all of the printers has the same issue. In the past we sold them also Ricoh printers, but there was no problem with the heap and stack settings. From the correspondence it looks as the memory Heap/Stack extension for Java for installing external applications is missing. So it seems it were other settings which came from our reseller. Since I'm not that experienced with printers, could you please tell me how to install a Java card to the C3500 printers?
        • 37685
        Unless the customer has Virtual Machine apps that they need to run, JAVA is not needed. It can cause a multitude of startup problems.
        • jordy144
          • Mar 2021
          • 7
          Hello,
          What do I actually need to solve my problem? I can not find much information about Ricoh printers and updating the java and firmwares, nor in the user manual. Unfortunately I do not have access to my-ricoh.com. I'm affraid that if we ask the customer to ship one back to us for investigation that the printer will be damaged due to transport considering the printers are in another country.
          • copier tech
            • 8267
            Originally posted by jordy144
            Hello,
            Why are you worried about the heap/stack settings? do you need to install software solution?
            โ€‹
            • TonerMunkeh
              Professional Moron
              • 3865
              Sorry I'm confused. What exactly is the problem you are having? As mentioned above, you do not need to install a Java card unless you are trying to install Java applications. It is an optional SD card:
              BRAND NEW GENUINE Ricoh VM CARD TYPE R (VAT INCLUDED) | eBay
              The xx03's, xx04's and machines around that generation had the Java on a flash rom on the controller, hence no need for a card.
              Hit it.
              • jordy144
                • Mar 2021
                • 7
                I'm a total noob regarding printers. Yes, they do want to install software.
                We sold the customer many Ricoh printers before, and there was memory available for the heap and stack settings. I do also not know why they want to use it, they probably use it in combination with a card reader. I'm very apprecieded if somebody can tell me how I can add memory to these settings. They are now threaten to send all the 4 Ricoh printers back to us, and they expect a solution. Unfortunately we do not have a Ricoh contract on these printers, so it's finding a needle in a haystack.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  They need Java cards.
                  Hit it.
                  • jordy144
                    • Mar 2021
                    • 7
                    Can you confirm if Ricoh VM CARD TYPE R is the correct Java Card for Ricoh C3500 model?
                    • copier tech
                      • 8267
                      No, spec shows VM Card Type M37 418410.
                      IM C3500 Color Laser Multifunction Printer | Ricoh USA
                      โ€‹
                      • Debs1964
                        • Oct 2010
                        • 1693
                        Is it an MP C3500 or IM C3500?
                        There are 10 types of people in this world, those who understand binary maths and those who don't
                        • jordy144
                          • Mar 2021
                          • 7
                          It's an IM C3500A model. If I purchase one on eBay, is there already a Java version installed on the Java card? If not, do I need access to my-ricoh to get Java installed to the Java Card?
                          • copier tech
                            • 8267
                            It is an optional extra card you have to purchase.
                            โ€‹
                            • Debs1964
                              • Oct 2010
                              • 1693
                              Most solutions now run on the SOP and don't require the optional Java card, you'll likely only need to purchase Java cards if the solution you're running is an old version
