Mpc4504 scan file name issue
  • digicor
    • Jul 2008
    • 1158
    How can I keep the file name after scanning for the next scan job with the same name,but different file number
    Meaning we need the keep the bulk of the scan name in place after scanning for the next scan without setting it to default screen. Batch won't keep it, timer is set to 60 seconds
    Still, after scanning the name dissappear
  • ridgemill
    • Sep 2017
    • 190
    Re: Mpc4504 scan file name issue
    Custom file names can be saved with a Program, if you are using the Scanner (Classic) application.
    Send File Type / Name > File Name
    Then Recall / Program / Change Program, and give it a suitable name.
    You can also set this program to appear on the home screen as it's own button, if needed.
    When the customer uses the program, the file name is re-filled; it won't remember the file name after a scan is complete.
    • digicor
      • Jul 2008
      • 1158
      i did try to use the program to keep the file name , it didnt keep the name just the settings
      how would i keep the name there?
      • digicor
        • Jul 2008
        • 1158
        is there a "recall" or previous scans that can be recalled and the file name be populated from the last scan?
        • Mark Bbb
          • Jun 2012
          • 1662
          • digicor
            • Jul 2008
            • 1158
            turn this off? or on? im sorry for the questions, or is it o to 1 or 1 to 0 thing?
              • 37514
              How about what ever it is set for change to the other option.
              • Debs1964
                • Oct 2010
                • 1693
                +1
                I couldn't remember which SP mode, but I knew it was in scanner SP
                There are 10 types of people in this world, those who understand binary maths and those who don't
                • digicor
                  • Jul 2008
                  • 1158
                  okay thanks very much, its default is 1 i set it to 0 whalah... bad news is the machine is a dog keeps catching at the transport, i have changed the transport three times, its a dog,(removed the finisher, leave the transport works fine) i removed the transfer section right after fuser, nothing is broken or out of place,
                  so were replacing the machine , and the finisher now "clicks" real bad when its jogging a big job... and i have to replace it with another ricoh mpc4504... i hope they get it right sooner or later
                  client even says thats why it only had 9k on it,, it didnt work....LOL
