mpc3003 romdata firmware
  • Mark Bbb
    • Jun 2012
    • 1662
    Hoi,
    We still have problems with updating firmware only on mpc3003.
    I think there is a failure in one of the firmware parts in the deeplink.
    Can someone provide us with the romdata firmware, please?
    It is the normal screen (not the SOP) and not the x, so the mpc3003sp.
    Thanks in advance.
    Greegins,
    Mark
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: mpc3003 romdata firmware
    on GWFCU firmware on deeplink Japan (for mpc3003sp), today:
    D1495559N Ver.12.00.00 2020/06/16 1,815
    But if i update (only) this, it displays: 'no valid data E36'
    On the self diagnostic page on the mpc3003, this GWFCU number is nowhere to find. In fact there are only D147xxxxx numbers on that diagnostic page, not a single D149xxxx. So i suppose this firmware needs to be updated.
    But it fails, why?
    My SD card is 100% ok and the root is
    'folder romdata' 'folder mpc3003sp' 'GWFCU data'
    Previous i have update - first - the sys cop and after that the engine. Than this GWFCU.
    I think this GWFCU holds an error!
    I always have troubles with updating a mpc3003. I do not understand the reason.
    How do you guys do this?
    • TonerMunkeh
      Professional Moron
      • 3865
      All I do when updating firmware is put the .fwu files in the romata folder. Never had a problem doing it that way.
      Hit it.
      • Mark Bbb
        • Jun 2012
        • 1662
        T.M., you use the deeplink Japan, i suppose?
        Or do you get it in another way?
        You are from the UK and we are here in Belgium, i suppose that can't be an issue?
        Would you please be so kind sending me this Romdata firmware sp?
        • TonerMunkeh
          Professional Moron
          • 3865
          PM me your email address, I'll send you a wetransfer link. What options does the machine have?
          Hit it.
          • Mark Bbb
            • Jun 2012
            • 1662
            I have dividend the firmware items into 3 blocks and... no problem!
            But... this message pop's up when i select 'power saving sys':
            'unselectable targets must be installed separately'.
            So, this must be updated separately... Who minds loosing (again) 10 minutes?
            This mpc3003 is rather difficult, no? I think it contains a very cheap processor.
            (Many thanks for your willing to help, T.M., but i think i can handle this further. )
            • copier tech
              • 8119
              Originally posted by Mark Bbb
              Hoi,
              Thanks in advance.
              Greegins,
              Mark
              Try update using the package file (.pkg) this will save you time adding all the individual romdata files.
              Or update the system/copy version D1475575R V1.37 first then your GW firmware.
              • Mark Bbb
                • Jun 2012
                • 1662
                The Browser file on the deeplink Japan is 9,430 KB, but the Browser file downloaded on my computer is 130 MB !!!!!
                How is that possible?
                I have deleted and downloaded all this files several times and still this file gets 130 MB on my computer!
                So that was the problem!
                Why can't i upload pictures on this site?
                • copier tech
                  • 8119
                  They are zip files so when you extract them they are larger.
                  To upload an image here it has to be 1mb or smaller so use ms paint etc & save the file size as 800x600 dpi etc.
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    Because some files are not up-loadable on the mpc3003, i have (again) deleted all mpc3003 romdata files and download them (again) on my computer.
                    But, my system has detected a virus on the mpc3003 firmware D1655703J, RPCS.
                    It's getting on my nerves now.
                    • copier tech
                      • 8119
                        • 37044
                        But it fails, why?
                        'folder mps3003sp' is not valid. It should be D149. There should not be any folders in D149, only .fwu files.
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          I don't understand why, but the downloaded and unpacked .fwu map-files of the c3003 contained other map-files, so many that it went over the 100MB for 1 file (f.i. Browser) only!
                          I have deleted all those corrupt files and downloaded it again from the deeplink, and now it is ok.
                          Virus?
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            But it fails, why?
                            Just use the package firmware it has gwfcu previous version also you don't need the folder mpc3003 just put the file in the romdata folder
                            Regards Mark
                            • copier tech
                              • 8119
                              "Browser file properties", directly after downloading and unpacking to my pc:
                              (why can't i upload any pictures?)
                              You would have seen 11,8 MB
                              "Browser file properties", after one night being on my lap top:
                              you would have seen 130 MB
                              D1475568M network doc box contains more files and is 121MB groot.
                              D1495564D animation id, 119 MB
                              D1655703J scanner id, 118MB
                              D1655754M browser id 130 MB
                              This should be a very simple process.
                              The folders should look like this on your SD card. You can have both the package AND the romdata or either one on their own.
                              ALL should be on THE ROOT of your SD card. (Note the file size of these pictures all way under 1mb)
