IM 550F question
  • K-3
    service technician
    • Feb 2018
    • 51
    IM 550F question
    is there a way to turn off/disable fax unit besides removing the unit as the customer does not need faxing at this time. the check status lite stays red as if there is a problem with machine, but it is not connected to a fax line.
    thanks
  • copier tech
    • 8144
    Re: IM 550F question
    thanks
    First address why you have the red light?
    You could uninstall the fax app (not just delete it)
    • K-3
      service technician
      • Feb 2018
      • 51
      the red lite is on because the machine detects that there is no dial tone (as the line is not plugged in ) you can clear by checking the check button but the message will come back if machine is turned off/on.
      • copier tech
        • 8144
        There is a setting to turn off line detection that will turn off the warning light.
          • 37490
          Also make sure that all automatic printing of reports is turned off.
          • skinnyb
            • Jul 2008
            • 291
            This. It is a feature of all the IM series units, if it doesn't detect a dial tone every so often it will throw a line error. It can be disabled in user tools.
            • K-3
              service technician
              • Feb 2018
              • 51
              thanks will check these out
