Pro C5100s - Skew trays 2&3
  • fatfingers73
    • Feb 2013
    • 219
    Hello,
    After some advice on this one. Getting terrible skew from these 2 trays.
    All feed rollers new, and reg unit also new.
    Tray 1 is fine.
    Vertical transport seems fine.
    Any ideas?
    Worked on these since launch and haven't had this before.
    Thanks.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Pro C5100s - Skew trays 2&3
    Easiest way is to print the trimming pattern and adjust the skew out per tray using SP modes. You can also do it in the Fiery if it has one.
    Is only the second side skewed or both sides?
    Hit it.
    • copier tech
      • 8144
      Originally posted by fatfingers73
      Hello,
      Tray 1 is fine.
      Any ideas?
      Thanks.
      Right door not closing fully?
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Hello,
        Tray 1 is fine.
        Any ideas?
        Thanks.
        If it's only on trays 2 & 3 most probably the right side door. Also check side guides in cassette and the black guide side of feed assy haven't broken off
        Regards Mark
        • Zaxxon
          • 608
          I know you say tray 2&3 but try to check registration roller for paper wrapped around.
          Please start you post with brand, model, problem.
          • copier tech
            • 8144
            He says the reg unit is new.
            • Zaxxon
              • 608
              My bad, sorry.
              • Imprestik
                • Aug 2012
                • 297
                There is a bulletin for this. You need to add a metal bracket to the locking mechanism on the door.
                Has this been done?
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Here you go RTB
                  Regards Mark
                  • satins
                    • Feb 2021
                    • 89
                    Is the tray 1 working fine without the skew or you are using a different paper for that tray?
                    Please be informed that the depending on the methods you use to correct the skew (device or Fiery).Please ensure that you have the same paper weight that you will will be using for production or output.
                    The skew correction can be better managed if you calibrate it with the paper that you will use for production.
                    Thanks.
