Ricoh pro c5300 sl
  • Mark Bbb
    • Jun 2012
    • 1662
    Ricoh pro c5300 sl
    Hoi,
    Is it easy to replace a fusing unit?
    Do I need special tools?
    (I have no service manual for this model)
    Thank you for your helping.
  • anothertech
    • 1771
    Re: Ricoh pro c5300 sl
    Yes it is easy. No special tools needed.
    • Gab
      • Aug 2015
      • 671
      too easy
      • JaysOnTheEDGE
        • 61
        Ricoh finally got it right with this fuser I've done one belt and I had the top half disassembled and the belt off in 10 minutes while following along the manual no special tools need. just your regular tools you would use for any other ricoh.
        • Mark Bbb
          • Jun 2012
          • 1662
          Is it correct that to get the fuser out there is only one screw (that is securing a plate) to be removed?
          Thanks for your answer.
          • JaysOnTheEDGE
            • 61
            Here are the TCRU manuals for the ProC5300S they have a PDF and HTML even got some videos on the HTML version.
            Pro C5300S/C5310S(TCRU) download page
