Ricoh MPC2503
  • Perry
    • May 2012
    • 9
    Ricoh MPC2503
    I have a Ricoh MPC2503 that constantly jams from the top tray. There is a small tear in the paper that is the same width as the sep roller. If I change the complete set of rollers, it will work great for about 20K. Then the same thing happens again. How long are the rollers supposed to last on this machine?
    • 37550
    Re: Ricoh MPC2503
    Normally caused by the separation turning in the reverse. Usually the result of a worn feed roller but if you are replacing it with a new Genuine Ricoh roller, try replacing the torque limiter for the separation roller. It may be binding and providing too much reverse torque. If you are using cheap after market parts, just remember
    • Perry
      • May 2012
      • 9
      Re: Ricoh MPC2503
      I'm using genuine Ricoh rollers so I'll order a torque limiter. Thanks for the reply.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Re: Ricoh MPC2503
        Use the mpc4503 rollers last longer also the problem is mostly limiter and lower separation roller good luck
        Regards Mark
        • tsbservice
          Field tech
          • 8028
          Re: Ricoh MPC2503
          Until failed torque limiter causes a flat spot on separation roller
          As others said change torque limiter together with rollers don't forget and change any oneways involved.
            • 37550
            Re: Ricoh MPC2503
            That depends on the type of roller and the paper being fed. It also is not a good value to base replacement on. As an example on the Martini models the older gray composite rollers were rated for 300K but with proper cleaning could last double that. On the other hand the blue synthetic rollers were rated at 1M but the feed roller seldom lasted more than 800K before they became too slick and allowed the separation roller to turn against them.
            • rthonpm
              • Aug 2007
              • 2859
              Re: Ricoh MPC2503
              I had a similar issue on years ago. Couple of other techs on the team had looked at it, cleaned or replaced rollers and the problem came back. I got there, pulled everything apart and found a small crack in the torque limiter at the end that went into the sep roller.
              Replaced it and life was good for the customer again.
              Sent from my BlackBerry using Tapatalk
              • emiliorsg
                • Jul 2018
                • 141
                Re: Ricoh MPC2503
                If the client is using used paper, many times it dirties the tires and then they slip, leaving a mark on the paper that they are not able to feed. If this is not the case, check the torque.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Re: Ricoh MPC2503
                  One of the belt assist feed rollers in the side door being stuck or slowed with paper dust is also a good cause for this.
                  Hit it.
