SC-320
  • Reeves
    • Apr 2012
    • 296
    [Error Code] SC-320
    I have a Ricoh Mp2510 with error code sc320 havr changed the polygon motor still the error code keeps on coming the machine ll be ready when I make a copy it ll pick the paper and jam at registration and gives the error code Sc320 I have changed the all laser unit still the error code keeps on coming what could be the problem
  • GIUBOSS
    • 1436
    Re: SC-320
    it is best to replace the entire laser unit
    to be careful, check the contacts of the pcdu unit
    • GIUBOSS
      • 1436
      Re: SC-320
      can be:
      - The motor itself or its control circuit, which is obviously malfunctioning
      - the connection between the motor and the board that controls it (BiCU)
      - the connection between the BiCU / IOB boards and the motor control circuit
      - the defective BiCU board
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Re: SC-320
        Did you fit new polygon motor or used also they are very fragile
        Regards Mark
        • copytrust
          • Feb 2010
          • 118
          Re: SC-320
          It could be the door switches or the drum unit, they were some models giving these errors sc320..........
