Ricoh MP7502 - FINISHER SR4060 jamming paper size A4U 240 x 330 mm
  • jma676
    Expert Tech
    • Mar 2009
    • 323
    [Jamming] Ricoh MP7502 - FINISHER SR4060 jamming paper size A4U 240 x 330 mm
    Hi there, last days MP allways jam A4U 240x330 mm paper in Finisher SR4060 entrance or Punch Unit (Without punch). Only when use DX mode un multicopy.
    Clearly jamming occurs with 240mm width size with Transport Roller: Entrance: Upper (B804 2131) waving paper in some way.
    Traying modify: Fusing temp, Fusing pressure. But Nothing work, or work temporarily.
    Note: 235 mm width work fine.
    Any idea?.
    • 37508
    Re: Ricoh MP7502 - FINISHER SR4060 jamming paper size A4U 240 x 330 mm
    Can you give us the numeric jam code?
    • copytrust
      • Feb 2010
      • 118
      can you remove the punch unit from the finisher? sometimes some of these punch units their <<teeths>> causing jams and staples fall in there from users you will need to examine the unit better
      • farhad
        • Apr 2020
        • 40
        Any idea?.
        in machines monitor you can see paper jm code
        in monitors upper right side
        for example(j016)
        this code say where in your machine have problem about paper jam
          • 37508
          for example(j016)
          You are 2 weeks late in asking the same question that was asked back then, If you cannot make valid contributions, go away.
          • farhad
            • Apr 2020
            • 40
            hahahaha
            • farhad
              • Apr 2020
              • 40
              You are a very narrow-minded and absurd human being
              You can not see anyone but yourself
              Please be yourself and stop jealousy
                Slim is a well known AND A WELL LIKED Senior tech here.
                He is willing to help anyone that needs it as long as they show a willingness to try.
                YOU on the other hand, can't even fill out your profile correctly.
                You are a SNIDE self absorbed person that shows you don't read the whole thread before commenting.
                Slim asked for the jam code 3 weeks ago, 5 days ago you jump in and suggest the same thing. Jma676 has been here since 2009 and looking at his profile is clearly a tech.
                You on the other hand joined us just a year ago ... are you a tech? Have you formally been trained on ANY office equipment? I sure can't tell by looking at your profile...
                About farhad2008
                Real Name:farhadCountry:IranGender:Male
                now look at that and tell ME why anyone should take you seriously! 39 posts 0 rep points.. you are nothing but a RED CARD collector.
                We here at CopyTechNet value SENIOR techs... but not a snide smartass.
                because of your comment to a senior valued tech, you have received another RED CARD and have been reported to ADMIN.
                IF you value your ability to leech off of this fine technical resource May I suggest you change your attitude and DO IT QUICKLY or you may find yourself BANNED FOREVER.
                Ponder that for a bit... and please do not respond to this .. just let my words ( as another SENIOR valued TECH ) sink in.
                  +1
                  • farhad
                    • Apr 2020
                    • 40
                    About farhad2008
                    I am a professional technician
                    Wools Unfortunately, I see here that some people do not allow a newcomer to work out of jealousy or self-interest.
                    Or mocking or insulting their tips
                    I received specialized training in Japan and China
                    I do not think most members of this site have seen this tutorial
                      well maybe just maybe you should fill out your profile to reflect your " qualifications "
                      the OP should know how to find JAM CODES but seeing how it has been three weeks he is either:
                      1) not concerned with the problem
                      2) too busy to check back in for further suggestions
                      3) has fixed the issue and has not told us that he has rectified the issue
                      Still that does not give you the right to be rude ..snide to others.
                      Certainly with all that " training " you received they taught you to ' play well with others" or is that just the way people from Iran treat others?
                      • farhad
                        • Apr 2020
                        • 40
                        I have many clients from all over the world and my relationship with all of them is very good and cordial
                        I apologize to all those who work on this site
                        Why ....
                        What should be the reaction of the members in the face of my mistreatment?
                          Why ....
                          There is only ONE person that "works" on this site the admin.
                          The rest of us here donate our time and knowledge and monies to keep the site running.
                          As far as your treatment of senior techs here, frankly you got what you deserve due to you attitude.
                          You claim to be a "professional"
                          START acting like it.. many of us have 20+ years in the industry and have been factory trained in multiple brands.
                            • 37508
                            Your attitude is not professional. Your being a newcomer has nothing to do with it.
