When print ink come out
    • 37065
    Re: When print ink come out
    Originally posted by zaidi911
    I already replace new fuser film
    Setting pressure roller to 800 in sp 1151
    Last what i do is install new driver it is XPS test print ok not all print it come like that some of file only.
    [ATTACH]49047[/ATTACH]
    Why are you using an XPS driver? XPS went out with Vista because both were a piece of crap. The broken lines in the image look like a very low qualty FAX print. Use the latest PCL6 driver for the least amount of trouble.
    You said in your first post that the MFP was an MP C3002. The C3002 has scan to memory device. Now stop all the screwing around and just scan a problem printout to either a SD card or USB thumb drive with the file type set as PDF and upload that PDF.
    • zaidi911
      • 10
      My default driver for MP C3002 is PCL6 , when i print using the pcl 6 driver for this excel file the print like a ink non stick that i attach here but when im using the xps driver it come ok like a normal print paper no ink non stick that why im asking here. Coz it happen only for MP C3002 the other mc not like this.
      #thank for someone tech me how to attach file or picture here.
        Check the excel file properties.. sounds like they have some weird settings for paper type.
          • 22973
          #19
          This sure looks like black developing to me. The diagonal voids are a dead giveaway. =^..^=
            I never doubt you but you have better detective skills than me. For starters, he's using a test page that doesn't show a lot to begin with...unlike a solid test chart. Secondly, I can't even see the entire page.
            • mikadonovan
              • May 2008
              • 2931
              #21
              It kinda looks like something may be wrong with the K PDCU. Print a color pattern in printer SP mode. If the problem resides with just the black, that is the issue.
              NEVER ASSUME ANYTHING
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                #22
                There's your problem did you just fit film or complete sleeve assy
                Regards Mark
                • zaidi911
                  • 10
                  #23
                  I completely assambly all part. And just change fuser film only not all part
                  • zaidi911
                    • 10
                    #24
                    Color pattern when i print it ok no problem ink proper stick in paper but when i print that excel file it become ink non stick in paper just that file another file i print ok no problem.
                      don't understand did you rebuild the whole fuser? thermostats-thernistors-bearings-pressure roller or just replace film? those other parts SHOULD be replaced also.. if NO then there's your problem.
                      • zaidi911
                        • 10
                        #26
                        Im just replace film, and will try the another part after this. I tq
                          NEVER half ass a rebuild on a fuser.
                          did you use an aftermarket film? another half ass move.
                            When I first saw the image it looked like a fuser problem to me. I agree with Phil, if you're gonna rebuild a fuser, don't half-ass it or it'll come back to bite you in the ass.
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              #29
                              Waste of time fitting cheap China parts that's way you can't buy from ricoh always fit complete sleeve
                              Regards Mark
                                China parts, just like the country they come from are CRAP.
                                i am having a hard time believing anything the OP tells us.. a 10year tech fumbling with such a simple problem amazes me.
                                i'd hate to see his recall rate.
