sc670_01 SC670_02 ricoh mpc307SPF
  • Adminofcopieur
    • Oct 2017
    • 8
    i have this error when the machine sleeps this night , and sometimes when printing and when starting..
    amazing
    any idea ?
    since i have changed the toner bk
    i replace him but no resolved...
    thanks for help me...
  • copier tech
    • 8174
    Re: sc670_01 SC670_02 ricoh mpc307SPF
    amazing
    any idea ?
    Faulty or dirty toner bottle contacts can cause this error. If not try updating the firmware.
    • Code: SC670-02
    • Description:Engine is down when machine starts up (SC reboot can not be performed)
      Machine-down was detected after the /ENGRDY signal was not asserted.
    • Causes:The engine board was reset at an unexpected time
    • Remedy:Update the firmware. Check the connection between the engine board and the controller board.
    • • If it is always reproduced, replace the engine board. If the problem persists, consider replacing the controller board or other boards between them.
      • If reproducibility is low, multiple causes are to be considered, such as software, engine board, controller board, and PSU.
      amazing
      any idea ?
      are you a trained tech?
      do you have the service manual? IF NOT place request for one here: https://www.copytechnet.com/forums/s...nual-requests/
      what happened before it kicked the code?
      was a repair done?
      user messed the machine up?
      more info needed.
      Phil B. " The Dentist "
      • Adminofcopieur
        • Oct 2017
        • 8
        was a repair done?
        more info needed.
        hello ,
        i am technicien since 10 years by I ve never seen this error.
        seams very difficult to find the real reason apparently
        the service manual had a correction , it s noticed that the toner bottle may be in cause
        i have service manual of course
        never happened before this code
        the user just changed the black toner before it s finished ..
        not repair done ,
        I just changed toner bk and all the color , be cause we re thinking it s about the chip toner bottle but none..
        what you would like I do ? changed the id chip sensor or the toner bottle assy ?
        I think it's not that because the code appear when the machine was sleeping ...
        I think I can look at the connector between the bicu and the controller card
        but any help appreciated
        sorry for the langage traduction , but I m French
        • copier tech
          • 8174
          hello ,
          not repair done ,
          If you have replaced all the toners & the toner chip contacts are clean update to the latest package AND any modules that are not in the .pkg file.
          • Adminofcopieur
            • Oct 2017
            • 8
            hi thank you for your response,
            but allready done
            • TonerMunkeh
              Professional Moron
              • 3865
              If it carries on playing silly buggers replace the toner hopper and the BRB board.
              Hit it.
              • Adminofcopieur
                • Oct 2017
                • 8
                hi thank for you reply
                i don t think it s a bout the toner hopper because the toner turn when I turn it ans there is no hard mechanical
                and now I have got sc 670-01 and not 670-02
                For THE BRB BOARD , it s maybe possible but what makes me doubt is that the code appeared when the machine was on standby....
                I were thinking better on bicu board control board and psu board...
                • imaginemoko
                  unTrusted Tech
                  • Jan 2008
                  • 289
                  may i suggest the PSU , Firmware then BICU last on controller for test isolation. good luck Sir.
                  fix the customer first then fix the machine... its simple and makes life more easy.
                  • Adminofcopieur
                    • Oct 2017
                    • 8
                    hello thank you for your answer
                    yes you can lol
                    but how I have a BICU in stock , I will test this first.
                    I give you return when done.
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      amazing
                      any idea ?
                      I've had this and it was a compatible toner try another bottle oem would be best
                      Regards Mark
                        Ricoh's really don't play well with compatible toners do they brother? well at least in my dealings with them.
                        • Debs1964
                          • Oct 2010
                          • 1693
                          I've had the same fault on a Metis with genuine toner
                          There are 10 types of people in this world, those who understand binary maths and those who don't
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            Same here on metis customer had oem toner so I thought I order the pwb was still the same replacement of new oem toner sorted problem I've even had oem toner with a missing chip in sealed box.
                            Regards Mark
                            • Adminofcopieur
                              • Oct 2017
                              • 8
                              no it s a genuine toner
                              and I have change 2 times black yellow magenta cyan
                              I just change one hour ago the bicu I m waiting for sc code return ...
                              so now I have the copy clear... look at the picture
                              all cables are ok
                              so it s why I think about psu problem...
