Blue line in B/W copies ( Savin 3535, Ricoh 3500 )
Getting an occasional cyan line on b/w copies or prints , looks like a streak of toner since its not an even line. I cleaned the cyan drum/dev unit, saw nothing unusual. Any ideas? transfer unit maybe, since color drums shoudnt even be turning for a b/w copy.
Tags: 3500, 3535, b/w, blue, cleaning blade, color drums, copies, dev, dirty, line, ricoh, ricoh 3500, savin, transfer unit -
gmann
blue line
I would replace the cyan pcu and if that dosent fix it i would replace the transfer cleaning blade...... -
I vote transfer cleaning assy (you can't get just the blade) first, then the transfer belt assy. I've also seen worn fusers and dirty fuser cleaning rollers give odd pcq on these machines.
I don't think it's likely the cyan unit as the toner won't likely fall up onto the transfer assy.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
2nd that.. transfer cleaning assemblyCompTia A+ Certified
CompTia Net+ Certified
CompTia Server+ Certified
CompTia Project+ Certified
OP Scanshare CertifiedComment
Thanks for the help guys,
I think the problem is fixed, it showed up after it ran an auto line adjust, where it lays colored lines of toner on the page, i replaced the transfer c/unit ran line adjust again and b/w copies came out clean after that. Why it was only blue that didnt clean off I am not sure, and also the cleaning unit had just been replaced 18k ago.Comment
