Ricoh MP 3053 side door issue
  • surecopy
    • Mar 2018
    • 42
    Having a problem with the side door lining up with the fuser release arms. I don't see anything broken or out of place. if you manually push in the release arms it closes fine. Is there any adjustments? So i have no clue on what I am missing. Any information would be appreciated. Thanks in advance Neil
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Ricoh MP 3053 side door issue
    This is common the arm bracket assy in the fuser unit is most likely bent damaged
    Regards Mark
    • KeviM
      • Oct 2019
      • 327
      Hello
      Like the previous guy said, the arms on the fuser unit which releases the pressure to remove paper jams are most likely bent out of position.
      What I normally do is remove the fuser unit and open the top cover of the unit. Then with the machine off, place the unit back with the cover off, follow the 2 plastic hooks on the duplex unit (the opposite cover that you opened) , now the 2 wheel bushings on the 2 arms from the fuser unit run along the opposite cover with the 2 plastic hooks when it's being closed. What you need to do is slightly bend the metal braces that hold the arms till you get the wheel bushings of the arms to run properly on the track with the hooks
      Be careful not to bend it too much or it could break off
        • 37628
        I have actually had to replace the entire fusing unit because the metal frame was warped. It was easy to see setting side by side with another fusing unit.
        • luca72
          • Oct 2017
          • 1792
          unfortunately, it has always been the weak point of those series that mount that release mechanism, the dynamics are the following: the machine jams repeatedly, and the customer gets angry and badly closes the hatch, there is no certain solution, the best hypothesis is that break, at least it is more difficult for the metal support of the fuser frame to deform, the best thing is to instruct the customer to close the door centrally, possibly also applying an adhesive, also as Slimslob says, I had to replace the whole unit-
          "I'll be back"
          • copyaction
            • Oct 2007
            • 991
            In one case where I had a customer continually breaking these, I modified the fuser removing the 2 arms and replacing the tension springs with longer ones. Never had an issue again.
            • surecopy
              • Mar 2018
              • 42
              Thanks everyone for your help. To copyaction wondering if you put longer springs does it always keep pressure on the two rollers?
              • copyaction
                • Oct 2007
                • 991
                Yes, just like the earlier generations of these.
