Mpc2003 faint colour pattern
  • Pixtech Frameworks
    • May 2020
    • 238
    Hi Everyone,
    I have a customer Ricoh MPC2003 on which CYMK are faint. I have force toner supply, TD initialization, changed toner to OEM, Color Registration, Auto Calibration, yet no solution. Attached is a copy of colour pattern for your view.
    Does anyone knows what could be cause?.
    Thanks.
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Mpc2003 faint colour pattern
    Originally posted by Pixtech Frameworks
    Hi Everyone,
    Thanks.
    What's pm parts life
    Regards Mark
    • copier tech
      • 8174
      Hi Everyone,
      Thanks.
      PCU life on the C2003/C2503 are only 60k check the PM life as Mark suggested.
        • 37533
        Your sample appears to be very weak on the yellow to the point where at first glance it appeared to be completely missing. You made no mention of whether you cleaned anything. Dust is your enemy. If you ran Auto Color Calibration in User Tools - Maintenance without first cleaning all the mirrors, the lamp and lamp reflector you wasted time. You also need to clean the Image Density sensor assembly and the laser shield glasses for all PCU. If the C2003 is not properly kept clean, you cannot expect good color quality.
        • tsbservice
          Field tech
          • 8020
          Hi Everyone,
          Thanks.
          Changed toner to OEM usually means your developers are gone thus faint colors
            • 37533
            But is it just OEM or Genuine Ricoh. OEM does not guarantee the quality of ingredients or production that Genuine does.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Every one is different on wording I say oem meaning genuine and compatible as fake
              Regards Mark
              • tsbservice
                Field tech
                • 8020
                Same here Mark.
                • tsbservice
                  Field tech
                  • 8020
                  Got it Slim. I meant OP stated that fake toner is out of machine now which in therms damaged/contaminated developer so by-by print quality.
                    • 37533
                    If it is made by or under contract for Ricoh it will say Genuine Ricoh. The term OEM is used by after market sellers to mislead people into buying their product. OEM merely mean that the basic components follow the recipe list but does not guarantee quality or particle size of those ingredients.
                      • May 2020
                      • 238
                      Mirror has been cleaned still the same.
                      I tried line adjustment mode c and a, both failed. Later auto Calibration and color Registration failed.
                        • May 2020
                        • 238
                        OPC Drum changed recently to OEM drum quality, still the same.
                        • copier tech
                          • 8174
                          Which PCU did you replace?
                            unless you deplete the crap toner in a development unit you will continue to have problems .. in fact you may need to replace them too.
                            using turdparty toners only causes more problems down the line.
                              • 37533
                              That usually means a dirty or damaged ID sensor.
