Apologies since this is an old topic,but wondering if you full time Ricoh gurus know if pump rebuilds work and the best source for rebuild parts? Also how cross compatible are the k pumps from different models?
MPC3000,3500,5000,etc toner pumps
Re: MPC3000,3500,5000,etc toner pumps
I have rebuilt a bunch.
bought 10 sets of that rubber piece that goes bad and pull the clutch apart and clean with lacquer thinner.blow all all parts..
A few worked but overall consensus not worth the time................only
in a pinch if needed. -
My 2 cents on that would be that I've heard of some having varying levels of success with rebuilding (As Andy Said), so my reaction is why bother wasting time with a process that doesn't have a high success rate?
Who wants (or needs) to be going back over and over to repair the same issue - particularly when the unit we're talking about just isn't very expensive.
As for interchangeability......There is no compatibility across generations of machines to the best of my knowledge.
I remember once trying a C2800 K pump in a C3500 (or vice versa) and it didn't work.
However, if I remember correctly, you can swap the Y/K pumps, and also the C/M pumps within the same model range. I believe the only difference being length of the hose that comes with them.Last edited by sandmanmac; 05-21-2021, 05:34 PM.Comment
I find it doesn't work out rebuilding waste of time. mpc3500 are smaller will not work in mpc5000 just look at the gear sizeRegards Mark
https://copierservices.simdif.comComment
Not worth it to rebuild them!
The MP C2000/C3000/C3500/C4500 all use the same pump. B2233255. It's the Black Pump, but it works on ALL colors.
The MP C2800/C3300/C4000/C5000 all use the D0293221 Pump. Same deal, it's the black pump, but works in ALL the color locations.OmertÃComment
hey sandy how is it up there in the great north?
Things starting to get back to normal?
take careComment
Not even close!
Slow roll out on vaccines which is picking up now, but can't even eat outside on a patio for at least a couple more weeks, and even outdoor activities like golf have been closed. The only place in the world (including the rest of Canada) that they are closed to the best of my knowledge.
Just stupid!
Finally opening those up tomorrow, but all non- essential businesses are still closed.Comment
hey that s a shame.
I got both shots a month ago and things are slowly reopening up.
The political climate has made nyc a disaster with most normal people
not wanting to return.
My brother is in VEGAS and they are going to be back to normal at the casinos
and restaurants by next week.
I am all for keeping people safe and living but the leadership here has been a danm
embarrassment ....
i am ready for the next MARS mission...........Comment
Hey Andy.
Not even close!
Just stupid!
Lockdowns and masks don't work.
Sent from my SM-G960U using TapatalkComment
hey that s a shame.
embarrassment ....
Don't know ANYONE who has gotten covid, I know people ALL over the country that are 50+.
I trust science and want to be able to protect those i am around too.Comment
It's been proven sunlight destroys covid.. so why keep indoors where the air is dirtier and recycled constantly.... most air filters are NOT changed on time and actually hurt the system by making it work longer and harder.
Again NO ONE I know has gotten sick and it's been proven in my state the numbers were greatly fudged upwards.
Vac out the existing hose and fit the new K pump in whatever colour was required.Comment
And if the Teflon coating on the inside of the hose to prevent clogging is damaged???Comment
out of personal curiosity I tried to understand the fault, using a bench power supply, on one that I replaced a month ago.
the problem seems to be the clutch, which has lost its strength, I replaced it with an MP2000 from the paper transport, but I haven't had the chance to test it yet, also because we only have a couple of units around that use that pump, I didn't notice any flaws in the rubber part, at least visuallyAttached Files"I'll be back"Comment
