Ricoh SG7100DN Error code 93300
  • copyman
    Owner / Technician
    • Sep 2005
    • 4701
    A customer called who I service their copier and said their Ricoh printer had code 93300. I don't know the printer that well but service manual shows code is for "HRB fuse blown". I've checked parts & service manuals and cannot find an HRB which assuming is a circuit board?
    Thanks in advance for any help to clear this code or what can be done to repair?
    • 37489
    Re: Ricoh SG7100DN Error code 93300
    It is most likely a fuse on the main power supply that powers what ever the HRB is. It is most like called something else in the replacement section on the SM and in the PC. Most likely differ labels in each. You could try the Point to Point.
    Seeing as how you are talking about a GelJet printer, my best recommendation is Run Forest Run as far away as fast as you can.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4701
      They claim they paid $1800 when I told them to throw inkjet out. So what you are saying in other words is "light fuse, get away" ........
      Advice well taken!
        • 37489
        Let's put it this way, if you search Ricoh's website for GelJet the products that come up are all discontinued. They were great in concept and as long as you didn't have a problem. Once your started having clogging problems your best option was to replace everything, head, gel tubes and cleaning station.
        • rthonpm
          • Aug 2007
          • 2854
          They still actually make these things, they're just branded under the Sawgrass name as opposed to Ricoh.
