MPC307 Manual tray
  • GeorgeBest
    • Jul 2009
    • 525
    MPC307 Manual tray
    Hi,
    And . . . customer asked is its possible that the manual feed overrules the cassette feed when you place a a sheet op paper in the manual tray.
    I thouhgt there is no adjustment for that in this model (?)
    Thanks in advance
  • dave w
    • Jun 2015
    • 230
    Re: MPC307 Manual tray
    As far as im aware - no priority settings for Bypass, Only tray 1 & 2
    • copier tech
      • 8142
      Originally posted by GeorgeBest
      Hi,
      Thanks in advance
      What if you configure the bypass with the correct weight/type the driver will automatically choose the bypass if the media matches.
      • sandmanmac
        • 3981
        Set up an additional driver for the machine called "bypass" and set the bypass tray as the default paper source, and they can just select the that printer when desired.
