Ricoh Pro C5100s close self checking
  • idea-design
    • Jun 2021
    • 4
    hi,guys!how to close self checking after Energy saving mode,does anyone know?lot thanks
  • copier tech
    • 8192
    Re: Ricoh Pro C5100s close self checking
    You can disable is service mode I guess you want to speed up the warm up process?
    However you may run into issues by doing this.
    • idea-design
      • Jun 2021
      • 4
      yes,and self checking will waste a lit toner。
      disable service mode,how can do it?need enter sp mode ?enter code?
      • copier tech
        • 8192
        Have a read of the service manual.
        Also update your firmware that will improve the first copy out time.
          • 37556
          It is most likely in Factory Service mode as I do not see it in regular SP in the service manual. You need to set it to only run Process Control if it has not been run within the last 24 hours.
