MP C3002 jam
  • menosmola
    • Apr 2014
    • 95
    MP C3002 jam
    Hi, can anyone help me? Jam in all zones, but there is no paper anywhere...
    Enviado desde mi Redmi Note 8 Pro mediante Tapatalk
  • COPIERMAN
    • Jun 2009
    • 559
    Re: MP C3002 jam
    If you were doing multiple copies start in bridge unit open both covers and work your way toward right side. possible one cover wasn't open
    • menosmola
      • Apr 2014
      • 95
      Re: MP C3002 jam
      That's the curious thing, this machine doesn't have bridge unit even if it indicates jam....
      • FrohnB
        • Jul 2017
        • 1919
        Re: MP C3002 jam
        J001 is a "power on" jam, meaning that it detects paper or dust at one of the sensors when the doors are closed.
        Have you cleaned all the sensors? There are two separate sensors on the paper feed stations. One faces out towards the right-hand door, and the other one is a couple of inches away (towards op side) and faces downward. Have had the ones that face downward get dusty and cause this jam.
        Otherwise, you have a small scrap of paper somewhere that is blocking a sensor, or a sensor that may have popped out of place, i think the one above the fuser is usually the one that gets dislodged.
        Omertà
        • FrohnB
          • Jul 2017
          • 1919
          Re: MP C3002 jam
          Just noticed that it's telling you there's "paper" in the duplex path - "Z" path.
          There's a sensor to check that is underneath the transfer case where the paper makes the turn to come back out of the duplex path.
          It's an upward facing sensor, and you have to pretty much remove that entire transfer roller case to see it. Have had scraps of paper cover that, and it gets dusty easily because it faces upward.
          Picture attached for reference on the location of sensor underneath transfer roller case.
          Omertà
            • 37488
            Re: MP C3002 jam
            What does the jam history in the SMC report show as the last jam? Any J001 will not be listed. A faulty door or cover switch will cause a jam to not be cleared. If power is then cycled the the machine will remember that there was a jam but not where it was resulting in the condition you have photographed.
            • anothertech
              • 1769
              Re: MP C3002 jam
              I'm figuring he's an end user, probably won't know how to use service mode.
              • menosmola
                • Apr 2014
                • 95
                Re: MP C3002 jam
                I know how to use service mode, thanks
                • anothertech
                  • 1769
                  Re: MP C3002 jam
                  Oh, good to hear. Go into IO mode and see what sensor is causing the problem.
                  • Gift
                    • Mar 2011
                    • 2459
                    Re: MP C3002 jam
                    Check the door switches and proper grounding of the transfer roller assy
                    • menosmola
                      • Apr 2014
                      • 95
                      Re: MP C3002 jam
                      I'm looking at the machine, no sensor works...
                      • Gift
                        • Mar 2011
                        • 2459
                        Re: MP C3002 jam
                        OK that's unlikely, no change of value even for simple stuff like "DF open/close"? something might stalling the SP-sensor check. So I understand you are not able to recover the "ready" condition at all if you open/close the door?
                        I had a one timer where I head to perform an engine reset, you might try this but uber-important: Backup the NVram first via NVram upload sp.
                        • menosmola
                          • Apr 2014
                          • 95
                          Re: MP C3002 jam
                          I tried a engine reset after backup, firmware update, change power board and ac control board, but nothing... I'm stubborn, I'm going to keep changing things....
                          • Gift
                            • Mar 2011
                            • 2459
                            Re: MP C3002 jam
                            OK - as I just notice it on your photo: does this very tiny red "Cover open" icon appear on the bottom left screen even if the cover/door is properly closed?
                            • Mark Bbb
                              • Jun 2012
                              • 1662
                              Re: MP C3002 jam
                              Replace all door & cover switches.
